Old 01-18-2023, 05:10 PM   #1
dip_fartson
Drives: 2017 BRZ w/ PP
Engine Rebuild - Lifter/Rocker Reinstallation
Overly ambitious noob here attempting to rebuild my motor after spinning a bearing...
In preparation to get the heads resurfaced and washed, the machine shop told me I needed to remove the cams, lifters, and rockers before drop-off. Unfortunately, I didn't take note of which lifters/rockers were paired or their original position on the heads.
Can the lifters/rockers be reinstalled in any order as long as the valve clearances are within spec?
dip_fartson is offline   Reply With Quote
Old 01-18-2023, 05:28 PM   #2
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Yes.
In theory, you keep the same lifters with the same rockers since they wear together. Not really a big deal though.
Old 01-18-2023, 09:24 PM   #3
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
As I understand it, the valve clearance is determined by the cap on top of the valve and the FA20 doesn't have much room for error. When I needed engine work done, I paid a professional. My wallet is lighter but my sanity is (mostly) intact.
Old 01-19-2023, 11:16 AM   #4
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Valve lash is adjusted through with the shim , but any change in the valve train between the head and cam can cause the lash to be different.
Old 01-20-2023, 10:46 AM   #5
blsfrs
blsfrs's Avatar
Thank you for finishing my thought.
Old 01-20-2023, 11:45 AM   #6
dip_fartson
I appreciate the input.
I suppose wear is relevant a factor. The parts have a little over 80k miles, which I think is fairly evident on the lifters:
https://pasteboard.co/3R01neYfzczQ.jpg
https://pasteboard.co/OExyGdp9WTu1.jpg
Is that an excessive amount of wear in your opinion?
I've gotten mixed responses about this on- and off-line. I'm leaning towards replacing all lifters/rockers just to be safe.
Last edited by dip_fartson; 01-20-2023 at 11:49 AM. Reason: Images didn't appear in post
Old 01-20-2023, 12:18 PM   #7
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
It's really difficult to tell with a picture. As long as there is no obvious damage I wouldn't be afraid to run it. I would check check the rollers and make sure they feel okay, no rough spots when turned or excessive play.
Old 01-20-2023, 01:59 PM   #8
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
lol sorry. I am a bit OCD about an incomplete thought.
Old 01-21-2023, 10:14 AM   #9
blsfrs
blsfrs's Avatar
Wear on some components does not seem to be an issue. When my engine was professionally rebuilt with 90k miles, many parts were reused. Rocker arms, pivots, cams, timing chains, etc.
Engine rebuild Milhouse86 DIY (Do-It-Yourself) Guides 19 07-11-2022 02:54 PM
Engine Problems with Rocker Arms Little Samurai FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 1 02-26-2022 09:24 AM
Wtb Engine rebuild in Phx Az Rogue.86 Arizona 0 01-20-2021 10:02 PM
Engine rebuild Locost7 Engine, Exhaust, Transmission 2 09-14-2020 12:50 PM
Engine noise (rocker arm?) 2013 BRZ CRJ Issues | Warranty | Recalls / TSB 11 07-24-2018 12:55 PM
