Old 01-17-2023, 09:16 AM   #1
dragoontwo
dragoontwo's Avatar
Drives: 22 BRZ limited
Second gen TSB database now with Hyperflash recall
This thread will serve as a TSB database for the second gen models. I will include what I think are the most pertinent TSB here. If you think there's one that is not listed but should be, let me know. The information will be as follows: Number(with hyperlink), revised date, content.
07-212-22, 11/17/22, Eyesight camera reprogramming
15-282-21R, 11/09/22, Starlink remote engine start diagnostic info
04-28-22R, 09/13/22, Squeaking sound occurs when turning steering wheel
Subaru Tech Tips, no date, EVAP diagnostics and testing
09-91-22, 07/08/22, Engine not cranking/starting
15-297-22, 07/01/22, Reprogramming file for Gen 4 Denso CP1 infotainment
07-206-22R, 06/12/22, Auto headlamp leveler updated part number
April Subaru tech tips, 04/01/22, Dark spot in headlights
06-84-22, 03/07/22, AT VDC reprogram
16-138-22, 02/01/22, AT TCM reprogram
15-290-22, 01/14/22, Homelink mirror inoperative
02-189-22, 01/04/22, Oil drain plug redesign
12-231-21, 11/19/21, Rear bumper installation tips
15-297-22R, 01/06/23, Reprogramming file for Gen 4 Denso CP1 infotainment
09-99-23, 01/24/23, Engine Surging/Jolting During Accelerator Release DTC P0011 & P0021
MY2312-250-23, 07/10/23, Rushing wind sounds from front door(s)
2022 BRZ/GR86 turn signal recall.
BRZ made between June 30, 2021 - APR 19, 2022
GR86 made between Nov 4, 2021 - APR 20, 2022
https://static.nhtsa.gov/odi/rcl/202...3V609-7844.pdf
https://static.nhtsa.gov/odi/rcl/202...3V609-6160.PDF
https://static.nhtsa.gov/odi/rcl/202...3V609-0466.pdf
Toyota Hyperflash recall doc.
https://static.nhtsa.gov/odi/rcl/202...3V609-8089.pdf
WRM-23(Hyperflash recall) parts and procedures.
https://static.nhtsa.gov/odi/tsbs/20...48200-0001.pdf
12-246-24, 05/04/24, Addressing lower right center panel gap
09-115-24, 05/14/24, New oxygen sensor P/N
dragoontwo is offline   Reply With Quote
Old 01-19-2023, 07:26 PM   #2
dragoontwo
dragoontwo's Avatar
Added April 22 tech tips that talk about headlamp dark spots. Page 5 number 7.
Old 01-20-2023, 07:29 AM   #3
I have requested that this thread be stickied.
Old 01-20-2023, 08:37 AM   #4
foshjowler
Drives: 2022 BRZ; 2014 BRZ
Having one about the hyperflash issue would be nice. It's so intermittent that I doubt it will replicate for them at the dealership.
2022 BRZ (sold)
2014 BRZ
2014 Cayman
Autox Videos
foshjowler is offline   Reply With Quote
Old 01-20-2023, 08:45 AM   #5
dragoontwo
dragoontwo's Avatar
Unfourtunately, nothing about that yet. On the other forum somebody may have it figured out. They only experience it with low Sun at the back of the car. When blocked form the sun it works normal, but with direct sun on the lamp it causes issues. I have my turn section tinted over and have never had this problem. They think that the Sun may be putting in trace voltage to the led causing the car to see it as a malfunction. Do you have your turn sections tinted? Would you be willing to get the overlays to tint them to find out if it fixes it for you?
Old 01-20-2023, 09:49 AM   #6
ichitaka05
Site Moderator
ichitaka05's Avatar
Drives: ichi 86 Project
Moved & stickied
Old 01-20-2023, 04:22 PM   #7
foshjowler
Very interesting. I assume these overlays are just a tint, and while I have an aversion to tinting lights as it makes it harder for people to see them, it's certainly worth a try. I wonder if just a UV filter would solve the issue too.
2022 BRZ (sold)
2014 BRZ
2014 Cayman
Autox Videos
Old 01-20-2023, 04:38 PM   #8
dragoontwo
dragoontwo's Avatar
Probably not a UV filter. My tint is the on lighter side. Visibility is fine during the day.
Old 03-14-2023, 12:01 PM   #9
dragoontwo
dragoontwo's Avatar
Added new infotainment upgrade.
Old 08-31-2023, 09:13 AM   #10
dragoontwo
dragoontwo's Avatar
Added MY23 wind noise from front door(s). For those with noisy front partition glass.
Old 09-07-2023, 12:43 PM   #11
dragoontwo
dragoontwo's Avatar
Added links to turn signal recall documents.
Old 02-01-2024, 02:15 PM   #12
dragoontwo
dragoontwo's Avatar
Added hyperflash parts and procedures.
Old 06-05-2024, 07:58 AM   #13
dragoontwo
dragoontwo's Avatar
Added panel gap and O2 sensor TSBs.
BBK Fitment Database? F1point4 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 164 02-09-2026 12:48 AM
I really like the new database error feature! nextcar Off-Topic Lounge [WARNING: NO POLITICS] 48 02-14-2020 02:27 PM
60-130 Vbox and 1/4 Timeslip Database spdbydesignchris Forced Induction 60 10-19-2014 03:52 PM
Dyno Database E92M3Guy Engine, Exhaust, Transmission 33 04-17-2013 10:20 AM
We should start a dealer BRZ order database eikond BRZ First-Gen (2012+) — General Topics 13 03-01-2012 12:56 PM
