Old 01-13-2023, 09:14 AM   #1
renzs1
Drives: toyota 86 gts 2016
(picture of) Where to get coolant source for turbo
Hey again guys! Would it be possible if someone send a picture of where you get your coolant feed and return for your turbo. I've watched hundreds of videos about turboing 86s but none of them really explains how they connect their coolant lines. I know its somewhere near the throttle body, but I just wanna see how/what it looks like. Thanks!
renzs1 is offline   Reply With Quote
Old 01-13-2023, 09:16 AM   #2
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Bottom barb is your feed, top is the return
JDL EL Recirc manifold, Boostlab BL58x Turbo w/ T51R, 17x9 ARC-8, IAG block
Old 01-13-2023, 12:08 PM   #3
Grady
Grady's Avatar
Exactly as above. And if you turbo just bypass the throttle body heater. Not needed with a turbo.
Old 01-13-2023, 04:47 PM   #4
Teseo
Drives: frs
Damn.... I dont remember how I routed the forester oem oil cooler
coolant source, turbo, water lines
Vacuum line & coolant hoses for turbo majixmatrix Forced Induction 6 01-14-2020 09:43 AM
Turbo Coolant Question James Russels Forced Induction 2 07-11-2019 05:29 PM
Coolant loss - Void Warranty/ Edit: coolant flush question BRZach Engine, Exhaust, Transmission 15 01-02-2016 08:21 PM
Turbo coolant lines GTX2867. Can I use the throttle body coolant lines? mike the snake Forced Induction 8 04-01-2014 05:56 PM
Full engine teardown picture thread. Taking requests. (PICTURE HEAVY!) nelsmar Engine, Exhaust, Transmission 53 02-28-2014 05:29 PM
