Old 07-10-2019, 04:26 AM   #1
James Russels
Drives: 2013 FRS
Turbo Coolant Question
For turbos that have coolant ports (specifically the Garrett GTX 2860R), I've seen multiple people say that the coolant intake should be the lower of the two ports, and the return should be higher. I was curious as to why this is. My thought process was that you'd want the fluid to flow from high to low, so this setup is counter intuitive to me.
James Russels is offline   Reply With Quote
Old 07-11-2019, 09:52 AM   #2
ATL BRZ
TEQSPORT Brand Manager
ATL BRZ's Avatar
Drives: '24 GR86 + '16 FR-S
Look up the first law of thermodynamics. You want the coolant to enter on the low side so that it enters the hot center housing and rises out of it on the high side after the heat is exchanged into the coolant, promoting flow.
Old 07-11-2019, 05:29 PM   #3
James Russels
Drives: 2013 FRS
Hey, thanks for the reply. Your video has actually been one of my main references for the install and it has been a huge help, so thanks a ton for posting that. I'm not a physics guy so I'm having a hard time understanding how the first law of thermodynamics would apply to this. Regardless of the heat, wouldn't the fluid still have to flow upwards, and therefore wouldn't that impede flow since it'd have to be pumped, versus flowing down with the assistance of gravity?
Question about coolant timmydatooth Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 35 11-04-2018 01:59 AM
Used FR-S coolant question HECK EM ALL Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 2 10-03-2017 09:14 PM
Coolant loss - Void Warranty/ Edit: coolant flush question BRZach Engine, Exhaust, Transmission 15 01-02-2016 08:21 PM
Coolant Question fantah Hawaii 0 08-01-2014 05:06 PM
Turbo coolant lines GTX2867. Can I use the throttle body coolant lines? mike the snake Forced Induction 8 04-01-2014 05:56 PM
