Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 2nd Gens: GR86 and BRZ > BRZ Second-Gen (2022+) — General Topics
BRZ Second-Gen (2022+) — General Topics General topics for the second-gen BRZ
Old 01-11-2023, 01:26 PM   #1
formulaBRZ
Resident Grannyshifter
formulaBRZ's Avatar
Drives: 2022 BRZ w/ STI aero
Trans & Diff Fluid Change at 10,000mi?
Hey all,
I'm considering picking up some Red Line MT-90 and 75W85 gear oil and having a reputable independent shop perform a trans and diff fluid change at 10k miles.
My idea here is similar to the philosophy of doing an engine oil change after the 1000mi break-in to flush any undesirable metals - However, I'd be doing the trans/diff after about a year of ownership.
It seems the general consensus is that factory fluids suck, but would swapping to Red Line and flushing the factory gear oil provide any benefit this early in the life of the car?
formulaBRZ is offline   Reply With Quote
Old 01-11-2023, 01:45 PM   #2
OkieSnuffBox
Drives: '23 BRZ Limited
Yes. I probably would have done it sooner.
I'm about to have the 1k mile oil change done on my '23. I plan on doing the trans/diff sometime between 1k-2k miles.
"95% of the time, more throttle is the answer. 5% of the time, it ends the suspense."
Old 01-11-2023, 01:52 PM   #3
formulaBRZ
formulaBRZ's Avatar
I did the same, and then again at 5000mi (dealer offered a 2x/year oil change program for dirt cheap so figured why not before the year ended).
Thanks for the feedback, glad I'm not the only one thinking about doing an early fluid change on the trans/diff. Longevity is the goal with this car for me so not opposed to some early TLC on the drivetrain.
Old 01-11-2023, 04:12 PM   #4
otter
Drives: 22 BRZ
Just note that the 2nd gen doesn't have the same trans fluid recommendations as the previous gen. It calls for LV - I put the Redline LV fluid in my trans at 5k miles. Haven't bothered with the diff yet (I'm at 9k).
otter is offline   Reply With Quote
Old 01-11-2023, 04:15 PM   #5
dragoontwo
dragoontwo's Avatar
Drives: 22 BRZ limited
This is true. I suspect that they made the move not for performance, but to try to eek out a bit more fuel mileage.
I have the RedLine MT-LV in mine now and have had no issues so far.
dragoontwo is offline   Reply With Quote
Old 01-11-2023, 04:34 PM   #6
formulaBRZ
formulaBRZ's Avatar
Thanks! Someone on another thread mentioned that this had changed as well. I think dragoontwo is exactly right that this change is for FE reasons. Interestingly, Red Line still recommends MT-90 for the 2nd Gen on their website. Probably just a carryover suggestion from the 1st Gen.
Since my BRZ is only on daily-driving duty for now it seems like sticking with the recommended LV oil might make the most sense.
Old 01-11-2023, 04:40 PM   #7
dragoontwo
dragoontwo's Avatar
Don't worry too much about it.
Old 01-11-2023, 05:00 PM   #8
formulaBRZ
formulaBRZ's Avatar
Much appreciated!
On an anecdotal level, are you satisfied with the MT-LV as an improvement over stock fluid? Noticeable difference? Main area I'm looking for improvement in shift feel is during those low temp shifts - maybe the first 5-10 minutes of driving where I'm still babying everything.
Old 01-11-2023, 05:55 PM   #9
OkieSnuffBox
Much appreciated!
For what it's worth. EVERY car I've ever put fancy synthetic fluid in the transmission has made them shift even worse when cold.
E30s, 350Z, MazdaSpeed 3, Mustang GT, 1st gen BRZ. But once warm, the shift quality is markedly improved over stock fluids.
Old 01-11-2023, 06:03 PM   #10
dragoontwo
dragoontwo's Avatar
Much appreciated!
For me, is day the MT-LV is about the same as stock.
Old 07-10-2023, 06:10 PM   #11
ruturaj001
Drives: BRZ 2023
I am curious what was the source (name of file) of this?
ruturaj001 is offline   Reply With Quote
Old 07-11-2023, 06:27 AM   #12
dragoontwo
dragoontwo's Avatar
The lower link in my signature.
Old 07-13-2023, 01:48 PM   #13
Ernest72
Drives: 16 Silver BRZ, 04 Silver WRX wagon
If it’s just a DD car then changing early is overkill honestly. I changed the diff fluid at 30k and the stuff came out looking the same as what went in.
Have not heard of any blown diffs.
The tranny and engine oil, probably would change more often, depending on your abuse, but better yet get and oil analysis and know where you stand.
Ernest72 is offline   Reply With Quote
Looking to change my trans and diff fluid soon, what your guy's go-to and why? 1234eher Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 68 06-22-2023 11:34 PM
Doing a trans/diff fluid change, are these oil good? bakingpancake Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 10 08-11-2022 03:40 PM
Trans and Diff fluid change feedback Freedom AFRICA 0 08-07-2015 11:52 AM
Manual Trans./Diff. Fluid Change.?. westmansweed Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 13 07-15-2015 08:02 AM
Trans/Diff Fluid. DanoFA20 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 18 01-11-2013 03:11 PM
