BRZ Second-Gen (2022+) -- General Topics General topics for the second-gen BRZ |
01-11-2023, 01:26 PM | #1 |
Resident Grannyshifter
Drives: 2022 BRZ w/ STI aero
Trans & Diff Fluid Change at 10,000mi?
Hey all,
I'm considering picking up some Red Line MT-90 and 75W85 gear oil and having a reputable independent shop perform a trans and diff fluid change at 10k miles. My idea here is similar to the philosophy of doing an engine oil change after the 1000mi break-in to flush any undesirable metals - However, I'd be doing the trans/diff after about a year of ownership. It seems the general consensus is that factory fluids suck, but would swapping to Red Line and flushing the factory gear oil provide any benefit this early in the life of the car? |
01-11-2023, 01:45 PM | #2 |
Drives: '23 BRZ Limited
Yes. I probably would have done it sooner.
I'm about to have the 1k mile oil change done on my '23. I plan on doing the trans/diff sometime between 1k-2k miles.
"95% of the time, more throttle is the answer. 5% of the time, it ends the suspense."
The Following 2 Users Say Thank You to OkieSnuffBox For This Useful Post: | formulaBRZ (01-11-2023), Pat (01-11-2023) |
01-11-2023, 01:52 PM | #3 | |
Thanks for the feedback, glad I'm not the only one thinking about doing an early fluid change on the trans/diff. Longevity is the goal with this car for me so not opposed to some early TLC on the drivetrain. |
01-11-2023, 04:12 PM | #4 |
Drives: 22 BRZ
Just note that the 2nd gen doesn't have the same trans fluid recommendations as the previous gen. It calls for LV - I put the Redline LV fluid in my trans at 5k miles. Haven't bothered with the diff yet (I'm at 9k).
The Following User Says Thank You to otter For This Useful Post: | formulaBRZ (01-11-2023) |
01-11-2023, 04:15 PM | #5 | |
Drives: 22 BRZ limited
I have the RedLine MT-LV in mine now and have had no issues so far. |
The Following User Says Thank You to dragoontwo For This Useful Post: | formulaBRZ (01-11-2023) |
01-11-2023, 04:34 PM | #6 | |
Since my BRZ is only on daily-driving duty for now it seems like sticking with the recommended LV oil might make the most sense. |
01-11-2023, 04:40 PM | #7 | |
The Following 2 Users Say Thank You to dragoontwo For This Useful Post: | formulaBRZ (01-11-2023), Pat (01-11-2023) |
01-11-2023, 05:00 PM | #8 |
Much appreciated!
On an anecdotal level, are you satisfied with the MT-LV as an improvement over stock fluid? Noticeable difference? Main area I'm looking for improvement in shift feel is during those low temp shifts - maybe the first 5-10 minutes of driving where I'm still babying everything. |
01-11-2023, 05:55 PM | #9 | |
E30s, 350Z, MazdaSpeed 3, Mustang GT, 1st gen BRZ. But once warm, the shift quality is markedly improved over stock fluids.
The Following 2 Users Say Thank You to OkieSnuffBox For This Useful Post: | AK2112 (07-13-2023), formulaBRZ (01-12-2023) |
01-11-2023, 06:03 PM | #10 | |
The Following User Says Thank You to dragoontwo For This Useful Post: | formulaBRZ (01-12-2023) |
07-10-2023, 06:10 PM | #11 |
Drives: BRZ 2023
07-11-2023, 06:27 AM | #12 |
The lower link in my signature.
The Following User Says Thank You to dragoontwo For This Useful Post: | ruturaj001 (07-11-2023) |
07-13-2023, 01:48 PM | #13 |
If it’s just a DD car then changing early is overkill honestly. I changed the diff fluid at 30k and the stuff came out looking the same as what went in.
Have not heard of any blown diffs. The tranny and engine oil, probably would change more often, depending on your abuse, but better yet get and oil analysis and know where you stand. |
Similar Threads | ||||
Looking to change my trans and diff fluid soon, what your guy's go-to and why? | 1234eher | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 68 | 06-22-2023 11:34 PM |
Doing a trans/diff fluid change, are these oil good? | bakingpancake | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 10 | 08-11-2022 03:40 PM |
Trans and Diff fluid change feedback | Freedom | AFRICA | 0 | 08-07-2015 11:52 AM |
Manual Trans./Diff. Fluid Change.?. | westmansweed | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 13 | 07-15-2015 08:02 AM |
Trans/Diff Fluid. | DanoFA20 | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 18 | 01-11-2013 03:11 PM |
