Old 01-06-2023, 09:40 PM   #1
STUNNAFC
Drives: 2015 Scion FRS
JDL Turbo Kit with no intercooler or charge pipe
i am looking into getting a jdl turbo kit but it does not include the intercooler charge pipe or piping for the intercooler.
Where can i get an intercooler and piping that would be compatible with this kit fitment wise and other things working perfectly.
Let me know would like something not too expensive as well.
One other question is if the downpipe is dented a bit would that be bad for the boost / turbo?
STUNNAFC is offline   Reply With Quote
Old 01-09-2023, 10:17 AM   #2
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
If it isn't new from JDL GFL hoping that's legit.
Why not ask JDL directly for the parts you are missing?
As for the "dent" probably not at all. A hot spot? Maybe.
Old 01-09-2023, 11:57 AM   #3
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
The generic FMIC kits for our car will likely be close enough to fit. I was able to make 3 different eBay FMIC intercoolers work with the JDL piping, it's just couplers and clamps that may vary. I'm not suggesting ANY of them will be a perfect fit, since your choice and turbo and its outlet are dictated mostly by the manifold's outlet flange placement and the turbo CHRA width, as well as the size of the compressor housing on the turbo and its own outlet.
Example- If you get some JDL hot parts kit and buy an eBay GT35 that has a 2.5 outlet and an old CHRA copy that is wider than normal, your turbo is not going to sit in the spot the turbo hot parts manufacturer (JDL) anticipated, and it's going to be "off" for fitment on anything anticipated to line up with the turbo position (including the downpipe).
It's best to buy buy it all in one go. I promise. I've had first hand experience on every facet of this, with this platform. I should've just bought everything from Jesse, the way I wanted it, the very first time.
JDL EL Recirc manifold, Boostlab BL58x Turbo w/ T51R, 17x9 ARC-8, IAG block
The Following 3 Users Say Thank You to DarkPira7e For This Useful Post:
Teseo (01-19-2023), Wally86 (01-11-2023), x808drifter (01-11-2023)
Supercharger charge pipe question Ashikabi Forced Induction 12 03-03-2016 09:31 PM
Intercooler without SC or Turbo Seth Hawkins Forced Induction 2 11-24-2015 08:37 AM
Need some help building my f.i charge pipe SavingManuals Forced Induction 7 04-11-2014 02:37 PM
How bad is turbo without intercooler? mid_life_crisis Forced Induction 50 06-23-2013 12:57 PM
would you turbo or super charge your BRZ/FRS? chenshuo Scion FR-S / Toyota 86 GT86 General Forum 45 03-04-2013 10:13 AM
