Old 01-04-2023, 06:55 PM   #1
traffic335
LSD Options / Recommendations
Looking into upgrading my differential. I am looking at REM coating the gears and going with an upgraded LSD. The Cusco differential cover also looks mighty nice.
Any preferences or recommendations between a Cusco Type RS 1.5 and an OS Giken SuperLock? This is for circuit use, not drift. It will be used on a 400+whp car with slicks.
Thanks all.
traffic335 is offline   Reply With Quote
Old 01-04-2023, 07:15 PM   #2
Pat
Pat's Avatar
Drives: 2023 BRZ
You may want to have a discussion about this with an experienced resource rather than trying to glean info from a forum. Talk with Counterspace Garage about the pros and cons of each available option. They have the knowledge to point you in the right direction while taking into account your goals and priorities.
Old 01-04-2023, 07:19 PM   #3
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
I would definitely reach out to @CSG Mike with diff questions
JDL EL Recirc manifold, Boostlab BL58x Turbo w/ T51R, 17x9 ARC-8, IAG block
Old 01-04-2023, 07:19 PM   #4
traffic335
Good idea Pat, I did read the thread below, but figured to ask since options and designs may have changed since 2016.
https://www.ft86club.com/forums/show...=100610&page=4
Old 01-04-2023, 07:48 PM   #5
SCFD
I swear by the OS Giken LSDs. The factory torsen LSD was actually my first complaint about the car.
SCFD is offline   Reply With Quote
Old 01-04-2023, 10:31 PM   #6
RedReplicant
Drives: None
https://www.facebook.com/ShaftworksUSA
RedReplicant is offline   Reply With Quote
Old 01-05-2023, 07:03 AM   #7
ZDan
ZDan's Avatar
Drives: '23 BRZ
I went with OSGiken 1.5-way on my LS3 FD. For track work, my preference is minimal breakaway torque with increased lock with applied torque from the ramps. In OSG this means more "negative preload". Went over my application and preferences with OSG tech and was very pleased with the result. Very transparent in operation, always provided max drive grip on corner exit. I would go in with an idea of what specific lockup characteristics you want and they can set you up with custom tune if that is required.
Old 01-05-2023, 08:49 AM   #8
MX-5RACER
MX-5RACER's Avatar
Drives: 2018 FA24 SWAP BRZ "ANNIE"
OSGiken units have a great reputation within the motorsports community, but keep in mind there will be set-up changes required to get the most out of the diff. I know quite a few people who have installed them, and the cars became pushy as the rear grip level out of a corner went way up. They made set-up adjustments and now love them.
DJ
2008 MX-5 PRHT "Violet"
2018 FA24 Swap BRZ "Annie"
MX-5RACER is offline   Reply With Quote
Old 01-05-2023, 09:48 AM   #9
traffic335
Sounds like OSG is the ticket. Thanks everyone for your input here.
Old 01-05-2023, 11:57 AM   #10
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
OSG all the way, talk to Shaftworks USA.
Cusco rear diff cover seems pretty "meh" since it's not smooth inside at all and the flow off the ring gear won't be smooth. See Banks' videos on youtube about their diff covers for trucks to see what I mean.
Old 01-06-2023, 08:08 AM   #11
ZDan
ZDan's Avatar
Drives: '23 BRZ
People think they want max breakaway torque, max lock all the time, when that’s unnecessary for most applications, sucks for handling, and wears out clutch plates faster as well.
Old 01-06-2023, 10:23 AM   #12
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
Correct, you want as little breakaway torque and as little lock as you can handle in most cases. A diff that's locked hard all the time just makes horrible entry understeer and snappy oversteer on exit because the car won't want to turn until you get some wheelspin.
Pondering audio upgrade options; have questions, want recommendations SilverlightPony Electronics | Audio | NAV | Infotainment 17 05-11-2014 05:38 AM
Scion FR-S options:what options did you have dealer installed? Scionshaun Scion FR-S / Toyota 86 GT86 General Forum 42 01-06-2014 01:35 AM
Bushing upgrades, geometry options and other component options? der_rainman Suspension | Chassis | Brakes -- Sponsored by 949 Racing 10 06-26-2013 12:53 PM
Canadian FR-S options VS U.S.A's options? Tino Scion FR-S / Toyota 86 GT86 General Forum 15 11-06-2012 10:07 PM
Gearing Options and Diff options airboy808 Engine, Exhaust, Transmission 26 12-25-2011 01:11 PM
