Drives: 2013 brz redheaded stepchild
PCV sucking oil after oil baffle plate install
Has anybody experienced the PCV system sucking a large amount of oil into the engine attributed to adding a GReddy Oil Pan Baffle Plate (or other brand)?
Rebuilt engine with about 100 miles. Naturally aspirated engine. Was driving some canyons at less than 5000 rpms. Did some hillcrests and shortly after a huge amount of oil smoke billowing out the exhaust. I confirmed that oil came through the PCV in the non-check valve line from the block direct to top of manifold. I pinched the line and drove the car for another few miles until oil in the exhaust burned off. 30+ miles with no issues since. |
I have the Greddy baffle since perhaps 25000 km, no issues like that...
| The Following User Says Thank You to gpvecchi For This Useful Post: | turboencabulatr (01-02-2023) |
Drives: 2013 frs base
I also have a Greddy and have had no problems.
| The Following User Says Thank You to blsfrs For This Useful Post: | turboencabulatr (01-02-2023) |
Rust bucket enthusiast
Have you checked your oil? Did you overfill? How was your ring gap for the rebuild??
JDL EL Recirc manifold, Boostlab BL58x Turbo w/ T51R, 17x9 ARC-8, IAG block |
| The Following 2 Users Say Thank You to DarkPira7e For This Useful Post: | turboencabulatr (01-02-2023), x808drifter (01-09-2023) |
#5 | |
not playing cards
#6 | |
It's not slow-ish consumption like ring gap or damaged ring. It was a very distinct single sudden event. Thanks for the feedback from other Greddy plate users. I will investigate my setup further for root cause. |
| The Following 2 Users Say Thank You to turboencabulatr For This Useful Post: | blsfrs (01-03-2023), DarkPira7e (01-02-2023) |
Drives: Crapcan
Only thing I could think is if assembling the engine on the stand they could have had some excess oil in it to lube parts. Rotating it on the stand put oil where it wasn't supposed to be and it burped it out on the drive. If it keeps doing it, may want to do a leak down. I'd just keep an eye on it for now.
Here are all the drains and passageways I could find in the block.
| The Following User Says Thank You to NoHaveMSG For This Useful Post: | blsfrs (01-06-2023) |
| Oil pan baffle plate | FreshBRZ | Engine, Exhaust, Transmission | 18 | 03-14-2021 09:24 PM |
| Oil pan baffle plate | twag4 | Engine, Exhaust, Transmission | 28 | 08-22-2019 07:48 AM |
| Greddy Oil Pan Baffle Plate | empower-auto | Engine, Exhaust, Transmission | 2 | 03-30-2017 05:08 PM |
| Popping sound after cam plate install | firestorm252 | Engine, Exhaust, Transmission | 1 | 04-19-2015 05:31 PM |
| Sucking sound upon throttle after Magnaflow Catback install | Thrustin | Engine, Exhaust, Transmission | 13 | 05-25-2014 02:05 AM |
