Old 11-09-2017, 11:34 PM   #1
twag4
Drives: frs
Oil pan baffle plate
Is it necessary? The upper oil pan already has a baffle, and some ribs in it that do some good in this regard. Is an aftermarket baffle really necessary for auto x and track work? I’m about to install my very expensive engine, and just want to hear from people who know stuff!
twag4 is offline   Reply With Quote
Old 11-10-2017, 03:36 AM   #2
Kodename47
Kodename47's Avatar
Drives: UK GT86
Cosworth now do one, tested to not cause oil return issues that has been seen on the Moroso one.
.: Stealth 86 :.
Kodename 47 DJ:
The Following User Says Thank You to Kodename47 For This Useful Post:
twag4 (11-10-2017)
Old 11-10-2017, 03:45 PM   #3
Hags86
Drives: Toyota GTS 86
The Moroso baffle is a mandatory requirement in the Australian Toyota 86 Race series. They are in the third year of the race series now.
See Appendix 1 of the homologation document below
http://www.toyota.com.au/86/~/media/...egulations.pdf
I've spoken to the engineer from the Technical Authority who designed and tested the race package. They used to get oil surge guring high G corners, now they don't. The 86 race series use a tyre that has less grip than a semi-slick (basically a high end street tyre) to limit costs. They aren't cornering on full-slicks: and still got oil surge before the baffle plate.
Hags86 is offline   Reply With Quote
The Following 4 Users Say Thank You to Hags86 For This Useful Post:
86raus (05-13-2018), J95 (01-05-2023), jliongh (06-02-2018), twag4 (11-10-2017)
Old 11-27-2017, 02:35 AM   #4
Decimus
BAE
Decimus's Avatar
Drives: Asphalt FRS
Not much info on baffles for our cars but moroso seems to be the most used one. Contemplating on getting one too but many say we still don't need it
Decimus is offline   Reply With Quote
Old 11-27-2017, 04:46 AM   #5
Walldodger
Walldodger's Avatar
Drives: Four wheels, two seats, etc
I track my car with Dunlop semi slicks and had oil pressure dropping on left hand corners.
It doesn't go to zero but it does drop. I don't remember what pressures, revs. If people say it's not needed, good luck to them.
Walldodger is offline   Reply With Quote
The Following User Says Thank You to Walldodger For This Useful Post:
Old 11-27-2017, 08:22 AM   #6
Lunatic
Lunatic's Avatar
Drives: 2015 Raven FRS
Did you install the Moroso Baffle Plate? Did it help?
Lunatic is offline   Reply With Quote
Old 11-27-2017, 09:26 AM   #7
Lunatic
Lunatic's Avatar
I see Greddy also makes an oil pan baffle, any comments on it?
Old 11-27-2017, 01:03 PM   #8
ls1ac
ls1ac's Avatar
If you are really worried about loss of oil pressure and are not under a rules constraint then an Accusump might be a better answer. If money is no object then dry sump.
The Following 6 Users Say Thank You to ls1ac For This Useful Post:
CSG Mike (11-27-2017), jliongh (06-02-2018), Joesurf79 (11-30-2017), Tristor (06-17-2019), Ultramaroon (11-27-2017), whataboutbob (04-22-2018)
Old 11-27-2017, 03:04 PM   #9
twag4
Drives: frs
I’ve already got one ready to go on.
Old 11-28-2017, 02:39 AM   #10
qijian
Drives: FRS
I ended up buying the BlueMoon baffle plate
qijian is offline   Reply With Quote
Old 11-30-2017, 09:03 PM   #11
Joesurf79
Joesurf79's Avatar
Drives: 2016 White Pearl BRZ Premium
Accusump. Easy, effective, and relatively cheap insurance when compared to a dry sump, and less wrenching to get in than to re-build the motor
Joesurf79 is offline   Reply With Quote
Old 12-10-2017, 01:36 AM   #12
Walldodger
Walldodger's Avatar
No I use the RacerX oil pan. The baffles aren't the best, but what I think is helping is the extra quart/litre of capacity. Since install, the pressure drops less frequently to a lesser degree while cornering.
I think using a baffle plate is a good simple solution.
More components = more to go wrong. Probably won't, but could.
Old 12-10-2017, 07:09 PM   #13
xwd
The RacerX pan does have some baffles which should help as well as the higher capacity.
I saw the comment before on return issues with the Moroso pan. I've only seen that mentioned in one thread, has that been an issue for other people?
Old 12-11-2017, 03:46 AM   #14
Kodename47
Kodename47's Avatar
Drives: UK GT86
Here's the Cossie one....
.: Stealth 86 :.
Kodename 47 DJ:
Greddy Oil Pan Baffle Plate empower-auto Engine, Exhaust, Transmission 2 03-30-2017 05:08 PM
Oil Pan Baffle BRZFRSSTORE Engine, Exhaust, Bolt-Ons 0 04-11-2016 09:52 PM
Moroso Oil Pan Baffle acj47 Engine, Exhaust, Transmission 6 03-05-2015 11:45 AM
Oil baffle wootwoot Engine, Exhaust, Transmission 3 12-24-2014 09:25 PM
Exhaust baffle/ box structure between cat and resonator? ahausheer Engine, Exhaust, Transmission 14 04-25-2012 01:57 PM
