Old 12-30-2022, 12:30 PM   #1
J95
J95's Avatar
How is this tyre wear?
It is a set of Yokohama v105, 245 40 r17
After 10k km these are the measurements (see %) relative to the previous measurements. No trackday, mostly highway
I might be running too much camber in the rear?
Now I got a set of Federal 595 RR and I will be tracking the car often, but also I will use the car for travelling. Im wondering if I need some new alingment. Currently it should be:
-1 front toe (each wheel)
0° rear toe
-1.2° front camber
-1.8 rear camber
(oem shocks with eibach lowering springs + front camber bolts)
J95 is offline   Reply With Quote
Old 12-31-2022, 09:01 AM   #2
ZDan
ZDan's Avatar
Drives: '23 BRZ
You’re totally fine…
Counter-intuitive tyre wear... grumpysnapper Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 03-30-2021 09:30 PM
Your experiences with camber and tyre wear Purist Suspension | Chassis | Brakes -- Sponsored by 949 Racing 8 11-20-2017 11:43 AM
Tyre Stretch, make ride higher? Bulgy tyre Codythatsme Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 06-20-2016 10:56 AM
Unusual tyre wear? (pics included) jourdanc Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 11 05-09-2014 06:34 AM
Tyre you will be getting Staticfrost AUSTRALIA 38 06-22-2012 09:02 PM
