Old 12-21-2022, 01:55 PM   #1
smoltz
Drives: 01 911 Turbo, 03 G500
GR86 Solo2DL - Wiring and DBC File
Just picked up a Solo2DL (with CAN Cable). There are instructions provided by AIM that indicate which pins to tap on OBD2 and a file in RaceStuido but I had read some posts here that the file isn't correct.
I think a few people here have this setup, can anyone chime in with some suggestions for wiring preferably so I don't need to cut factory harness.
smoltz is offline   Reply With Quote
Old 12-21-2022, 02:49 PM   #2
askho
Drives: 2013 Subaru BRZ
I don't believe you can get can data on the obd2 plug in the gen2 86. You'll need to pull it from some other place on the can network. The most common place is the noise generator ECU. Ansix auto makes a adapter:
https://ansixauto.com/2022-brz-gt86-can-adapter/
Or you can make your own.
askho is offline   Reply With Quote
Old 12-21-2022, 03:40 PM   #3
smoltz
Thanks!
Old 12-21-2022, 03:53 PM   #4
smoltz
Anyone have the DBC files, maybe @CSG Mike
San Diego: 2022 GR86 OEM Premium GR86 Rims GRime86 Wheels and Tires 3 12-10-2022 04:52 PM
GR86 In R7 of the Toyota Gazoo Racing GT Cup + GR86 coming to Grand Turismo Sport Blighty GR86 General Topics (2nd Gen 2022+ Toyota 86) 28 07-18-2021 03:38 PM
BIN FILE TO XML FILE? Nobunnyhere.86 Software Tuning 3 10-06-2017 07:46 PM
OFT - Mode file not found. Cannot create a tuning file. focobrz Software Tuning 11 07-17-2015 09:22 PM
usb mp4 file format wrohdejr Electronics | Audio | NAV | Infotainment 1 04-16-2013 07:19 PM
