Old 12-15-2022, 01:45 PM   #1
nixsin
Drives: 2015 BRZ
BRZ Will not start-tried everything
Yes, I've tried that, I promise.
It's been at the dealership for a month and a half awaiting a DIAGNOSIS and they either will not or cannot figure out what is wrong with the car that is keeping it from starting. Apparently there is another car there with the same exact issue and they can't figure it out on that one either.
Who can I contact at Subaru about this? I am just looking for a way to get some transparency on this process as the dealership hasn't been responsive and only gives updates when I call and ask for them. It's been a month and a half and at this point I'm going to be forced to sell the car at what I assume will be a huge loss because it won't start, because I need a car. Please, if you have gone through this, let me know what you did to contact Subaru or solve this problem. I am getting pretty desperate here.
I'm not asking for suggestions on how to fix the car. It's at the dealership. I don't even have it here to look at myself if there is a suggestion I haven't tried. But I promise I've tried them all.
nixsin is offline   Reply With Quote
Old 12-15-2022, 02:41 PM   #2
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
This sounds like a post out of frustration so I am going to do my best to step out of character and be polite.
You can call Subaru of America's customer support line. But keep in mind, the dealership doesn't really work for them so the help you get may be limited.
You can talk to the dealer and try to find out what is taking so long. Shortage of workers? They have no clue and they are waiting on Subaru's own service guy to help them?
You can try taking the car to another dealer.
Old 12-15-2022, 03:06 PM   #3
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Imagine my reaction when my control arm broke on my 03 wrx and it took them 2 months to replace both sides under recall.
MSG is right, contact SOA customer support. If you're annoying enough, they will put heat on the dealership
JDL EL Recirc manifold, Boostlab BL58x Turbo w/ T51R, 17x9 ARC-8, IAG block
Old 12-15-2022, 05:06 PM   #4
Grady
Grady's Avatar
Have you tried tuning the key clockwise?
Sorry could not resist, I know that can be frustrating. Do we know why it will not start? 3 possibilities besides a mechanical failure internal to the engine.
Does not crank?
Cranks but no fuel?
Cranks but no spark?
Has a leak down test been done?
Old 12-15-2022, 05:20 PM   #5
nixsin
Drives: 2015 BRZ
Does not crank?
Cranks but no fuel?
It does nothing. Literally, NOTHING. I tried EVERYTHING. It is an electrical failure.
Old 12-15-2022, 05:24 PM   #6
nixsin
Drives: 2015 BRZ
They have been getting all instructions directly from Subaru on what to try in order to fix the car and each time they're 'waiting' for subaru it's a two week interval of nothing happening. I unfortunately can't bring it to another dealership without spending hundreds on a tow *again*. As I said I'm at the point where I'm literally just going to sell it for scrap and take a huge loss sans Subaru swooping in with a miracle. I need to contact someone at Subaru. I have submitted to SOA customer support as of this morning.
Old 12-15-2022, 05:47 PM   #7
nixsin
Drives: 2015 BRZ
trouble code is B2782. I promise, I have tried everything, and then the dealership has tried all of that again.
Old 12-15-2022, 05:56 PM   #8
Grady
Grady's Avatar
I guess you are going to say they tried a new ECU?
Old 12-15-2022, 06:00 PM   #9
nixsin
Drives: 2015 BRZ
The ECU is fine and worked in another BRZ. The IBU was replaced and changed nothing.
Old 12-15-2022, 06:05 PM   #10
Grady
Grady's Avatar
Did you double check and verify a good ECU does not work in yours?
If so then That is a fun one. Hope there is a good technician working on it. They will figure it out eventually but some times these things can be a royal pain!
Old 12-15-2022, 06:14 PM   #11
nixsin
Drives: 2015 BRZ
I would assume that the dealership tried this on one of the two cars that are in with the same issue. I tried my ECU in a friend's car and it worked fine. Didn't want to hook up a good one to my car and have this problem become double.
Old 12-15-2022, 06:30 PM   #12
Grady
Grady's Avatar
I feel for you. Hope the technician is good. Is there another Dealer close to you? The problem is the technician working on it is not going to make any money. So unless he has pride in his work/abilities you may be put off to the side while he works more lucrative projects.
Old 12-15-2022, 07:07 PM   #13
nixsin
Drives: 2015 BRZ
No, and this one is 20+ miles away from any other dealer so if I get the car towed I'm out hundreds of dollars
Old 12-15-2022, 07:53 PM   #14
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
To be fair, that code looks like a nightmare to deal with. I found one thread on it with no resolution. One youtube video on it and the english translation of the issue doesn't tell you anything.
When you say ECU, did you swap the ECM on the passenger side, or the main body ECU on the driver side?
b2782
Stall/No Re-start with push button start couver Scion FR-S / Toyota 86 GT86 General Forum 11 06-26-2020 10:32 PM
FS: STI engine start push start OEM plug and play sokol Interior Parts (Incl. Lighting) 5 06-13-2019 02:12 PM
Car won't start. Limited with push to start. uEih Issues | Warranty | Recalls / TSB 22 01-06-2017 11:54 AM
Pop-Start with Push-Button Start cmspooner BRZ First-Gen (2012+) — General Topics 5 03-22-2013 02:45 PM
Push Start Rough Engine Start Up joergasm Engine, Exhaust, Transmission 3 12-12-2012 03:44 AM
