Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 2nd Gens: GR86 and BRZ > BRZ Second-Gen (2022+) — General Topics
BRZ Second-Gen (2022+) — General Topics General topics for the second-gen BRZ
Old 12-14-2022, 10:41 AM   #1
FastLap
Drives: 2025 Toyota GR86 Premium PP
Headlights not so bright?
Anybody else feel like the headlights aren’t that bright? I’ve got two other newish cars with OEM LED headlights and they seem way more useful at night. On the BRZ I feel like I’ve got cheap aftermarket bulbs or something and the light doesn’t seem nearly as bright or far reaching as the other cars.
FastLap is offline   Reply With Quote
Old 12-14-2022, 01:04 PM   #2
Desertnate
Spelling Impaired
Drives: 2022 BRZ Limited WR Blue
Overall I'm pretty happy with them. I was driving in a heavy rain last night and could see the road better than other cars I've owned, even those with OEM HID's. In fact I was able to spot some deer on the side of the road I'm not sure I would have seen on many other vehicles.
I think the light output is good, but the could be aimed a bit low. However, it seem most OEMs tend to aim HID and LED lights lower to reduce glare for oncoming vehicles.
Desertnate is offline   Reply With Quote
Old 12-14-2022, 02:28 PM   #3
MyHybridBurnsGasAndTires
Drives: what
OP, i think they're fine on the BRZ but i gotta ask, are you absolutely sure you've got the lights on and you're not driving with the DRLs on?
modern cars dont do a good job of letting the driver know if the DRLs or headlights are on. 15 years ago most cars didnt have a digital dash so if you started driving without your lights on you couldnt see your gauges, and serves as a reminder to the driver...but modern digital dashes are bright and they dont notice if they're using DRLs or no lights at all.
most companies just do a terrible job aligning headlights
from the IIHS:
The Institute released its first headlight ratings in 2016. Out of more than 80 headlight systems available on the 31 model year 2016 midsize cars that were evaluated, only one system received a good rating.
About 1 in 3 headlight systems tested on model year 2022 vehicles earn a good rating. About 40 percent of the systems tested are rated marginal or poor because of inadequate visibility, excessive glare from low beams for oncoming drivers, or both.
i regularly run outside at night and the number of vehicles blinding me is too many to count. i'm 6'4" so my eyes are higher than the headlights on all these fucking SUVs but they're aimed so poorly (or the morons driving them have their brights on but that's a separate issue)
MyHybridBurnsGasAndTires is offline   Reply With Quote
The Following 2 Users Say Thank You to MyHybridBurnsGasAndTires For This Useful Post:
soundman98 (12-14-2022), Ultramaroon (12-15-2022)
Old 12-14-2022, 02:33 PM   #4
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
I'd start by checking if they're adjusted correctly.
I'd be willing to bet they're a bit low.
The Following User Says Thank You to RToyo86 For This Useful Post:
x808drifter (12-16-2022)
Old 12-14-2022, 03:49 PM   #5
AK2112
AK2112's Avatar
Drives: 22 BRZ
the headlights are real good
AK2112 is offline   Reply With Quote
Old 12-15-2022, 01:53 AM   #6
FastLap
Yeah, they're definitely on. They do the alignment pattern at startup since I have the Limited model and the green headlight indicator is on on the dash.
It could be that they are lower than other cars but not sure. The also have PPF on them but as far as I know that shouldn't be reducing the output any.
Old 12-15-2022, 08:45 AM   #7
Desertnate
Spelling Impaired
Not only is it an aim issue, but also a lamp design problem. Around here people use super duty pickups as cars for normal transportation. The Fords in particular simply blast out light all over the place. The lenses don't actually focus light anywhere but simply take the flood light approach. Who cares if you blind everyone else on the road.
Automatic high beam systems aren't much help either. They are horribly slow to adjust in many cases.
The Following 3 Users Say Thank You to Desertnate For This Useful Post:
CaptainFenderbaum (12-15-2022), DocWalt (12-20-2022), MyHybridBurnsGasAndTires (12-15-2022)
Old 12-16-2022, 11:26 PM   #8
Squirrely
Drives: 2023 BRZ, LTD, MT
I think they're great, but I find them to be a bit low. I have the limited, so I wonder if that is affecting it.
Squirrely is offline   Reply With Quote
Old 12-17-2022, 02:29 AM   #9
FastLap
Maybe… maybe the auto leveling keeps them a tad low?
Old 12-17-2022, 10:29 AM   #10
RToyo86
RToyo86's Avatar
Do the gen2s use the same adjuster that attaches to the driverside LCA?
My 2017 lowered on its own after swapping out for SPC LCA. I never measured the difference but it was enough that I actually usey high beams on backroad where I never felt the need for them before.
Old 12-17-2022, 11:31 AM   #11
otter
Drives: 22 BRZ
The output is fine but they're aimed too low from the factory, been meaning to adjust mine. Each headlight housing has two vertical adjustment knobs that you can get at with a long flathead screwdriver from under the hood.
otter is offline   Reply With Quote
Old 12-17-2022, 03:23 PM   #12
humfrz
Welp, maybe this is your situation.
As I get older, I notice that my headlights get dimmer. They are practically useless on rainy nights. However, the headlights on oncoming traffic are blinding, almost like I've been hit with a laser -
g e (12-19-2022), Vr4gasmtt (12-20-2022)
Old 12-19-2022, 05:40 PM   #13
g e
Is there a manual headlight leveling dial on the Gen 2 cars?
My 2013 has that and let’s one dial in where the beams light the road. Up and down only.
My Limited has fantastic headlights. Far better than my wife’s Lexus Nt
g e is offline   Reply With Quote
Old 12-20-2022, 10:32 AM   #14
otter
Drives: 22 BRZ
Yes, two per headlight that you have to adjust equally. There's a blurb in the manual about it as well as markings/sticker on the housings themselves.
Winjet foglights too bright? ThisGuyRett Cosmetic Modification (Interior/Exterior/Lighting) 0 08-03-2016 07:22 AM
Headlights - Bright Enough? lfgrdwill BRZ First-Gen (2012+) — General Topics 31 08-30-2014 09:18 AM
My car got broken into. Thieves not too bright... hansthegerman Scion FR-S / Toyota 86 GT86 General Forum 17 10-26-2013 05:41 PM
Are Your LED's Bright Enough?? Check This Out! 86_ZN6 Cosmetic Modification (Interior/Exterior/Lighting) 4 09-19-2013 06:31 PM
Bright White LED Headlights and Front Signals ScionFR-S Cosmetic Modification (Interior/Exterior/Lighting) 13 11-12-2012 09:46 PM
