Old 12-06-2022, 12:11 PM   #1
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
TBW Underbody Protection Panels
Bought these on a whim because I haven't seen anyone else try and and I need an aluminum base to start building ducting from.
Fits very well, most holes are slotted so you get a little wiggle room where it matters. My front bumper has been through hell and I've hacked off a lot of the underside. They supply pop clips to fasten the splitter portion that replaces the plastic one to your bumper, neat! I used zip ties for now.
Engine guard that replaces the existing aluminum one fits perfectly, even adds a little clearance, now my JDL turbo manifold isn't touching it. The oil change panel even fits with a fumoto valve installed!
This was $209 USD W/ free shipping, I am impressed!
https://www.ebay.com/itm/354219331233
JDL EL Recirc manifold, Boostlab BL58x Turbo w/ T51R, 17x9 ARC-8, IAG block
The Following 9 Users Say Thank You to DarkPira7e For This Useful Post:
blsfrs (12-06-2022), Dzmitry (12-06-2022), Jdmjunkie (12-06-2022), norcalpb (12-06-2022), pope (12-08-2022), RedReplicant (05-08-2023), Ultramaroon (12-06-2022), Wally86 (12-07-2022), whataboutbob (05-07-2023)
Old 12-06-2022, 05:11 PM   #2
norcalpb
norcalpb's Avatar
That looks great! Does the front piece simply replace this oem piece?:
Old 12-06-2022, 05:38 PM   #3
DarkPira7e
DarkPira7e's Avatar
As far as I know, yup! I removed that and the thick plastic splitter when I bought my car so I don't know if the coverage is the same though
The Following 2 Users Say Thank You to DarkPira7e For This Useful Post:
norcalpb (12-06-2022), Wally86 (12-07-2022)
Old 05-06-2023, 07:25 PM   #4
dynarun55
dynarun55's Avatar
Drives: 2015 midnight blue limited edition.
Hey man! How is this holding up now ? Any issues ? Thinking of buying this instead of the oem crap.
dynarun55 is offline   Reply With Quote
The Following User Says Thank You to dynarun55 For This Useful Post:
DarkPira7e (05-06-2023)
Old 05-06-2023, 08:03 PM   #5
DarkPira7e
DarkPira7e's Avatar
They are doing great! My front piece is just zip tied to some holes I smoked into the lip on my front bumper, they're solid. I like that there's a door that covers the oil pan drain plug
Old 05-07-2023, 11:12 AM   #6
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
FWIW: You might consider using 1/4"clip nuts and screws on the bumper instead of zip ties. I'd be worried that chafing or an accidental scrap on a curb would cause the zip ties to fail. And you know, it wouldn't fail in a parking lot. It would fail when you are doing 75 on a back road.
Old 05-07-2023, 01:39 PM   #7
DarkPira7e
DarkPira7e's Avatar
They actually include a bunch of those. I'll get to it sometime
The Following User Says Thank You to DarkPira7e For This Useful Post:
blsfrs (05-07-2023)
Old 05-07-2023, 11:15 PM   #8
Turdinator
Señor Member
Turdinator's Avatar
What is the advantage these have over the stock pieces?
1974 TA22 Celica
2013 86 GT
Old 05-08-2023, 07:50 PM   #9
DarkPira7e
DarkPira7e's Avatar
I lost my stock front undertray a very very long time ago, and wanted something aluminum I could build ducting onto. The back piece is less robust than the stock one, but lighter by a bit, and covers the oil pan completely (good and bad, if you rely on that air for cooling). Certainly not worth it if you've got all the stock assembly, cool for bling otherwise. Also much faster to remove than the stock pieces, which is something I need because my bumper is on/off all the time
Turdinator (05-09-2023)
Old 05-08-2023, 08:29 PM   #10
blsfrs
blsfrs's Avatar
Using advanced CAD (Cardboard Aided Design) techniques, I'm making an extender to go behind my spiltter. This might smooth out the air flowing under my car and give me 0.000025% less drag. My sheet of 1/4" composite aluminum was delivered today. Using an ocular guided reciprocating cutting tool, I should be able to cut it out and finish it this weekend. Barring any unanticipated honey do jobs.
The Following 4 Users Say Thank You to blsfrs For This Useful Post:
DarkPira7e (05-09-2023), new2subaru (05-08-2023), Ruben_86_ (05-30-2023), whataboutbob (05-28-2023)
Old 05-09-2023, 08:19 AM   #11
Wally86
Be Kind
Wally86's Avatar
Drives: 2020 86
Besides the prettiness? I'd say the convenient oil drain cover.
[Insert clever signature here]
IG | WhiskyBlog | Photography
Wally86 is offline   Reply With Quote
The Following 2 Users Say Thank You to Wally86 For This Useful Post:
blsfrs (05-09-2023), DarkPira7e (05-09-2023)
Old 05-09-2023, 11:00 AM   #12
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
The stock pieces also don't stand up to random off road excursions very well
The Following User Says Thank You to NoHaveMSG For This Useful Post:
blsfrs (05-09-2023)
Old 05-28-2023, 09:28 AM   #13
blsfrs
blsfrs's Avatar
I'll take off the protective covering on the final install.
FS: JDM OEM Underbody Panels Hanakuso Exterior Parts (Aero, Lighting, Etc.) 5 01-19-2016 10:10 PM
Do Canadian 86s come with underbody panels? funwheeldrive Scion FR-S / Toyota 86 GT86 General Forum 21 02-16-2015 12:31 AM
JDM Underbody Panels aznatama Exterior Parts (Aero, Lighting, Etc.) 34 06-14-2014 04:38 PM
JDM Underbody panels Laika Exterior Parts (Aero, Lighting, Etc.) 6 02-05-2013 08:23 PM
GTA - JDM underbody panels? wparsons CANADA 7 11-24-2012 12:18 AM
