Old 08-17-2014, 07:18 PM   #1
v86
Kid Gt86
v86's Avatar
Drives: SRT / Pulley / Tuned / Drop in
Is she healthy, log. OFT
My car has been acting real sluggish ever since I went with the modified version of the 2.0 for BPB.
My mods are the following:
SRT Full System Exhaust
Mishimoto inlet hose
Perrin crank pulley
Perrin drop in
Crawford BPB
Stage 1 OFT tune
Now, this log was taken 30 minutes after being re flashed.
Let me know if everything looks OK.
http://www.datazap.me/u/jokie/learni...e?log=0&data=1
v86 is offline   Reply With Quote
Old 08-17-2014, 07:41 PM   #2
phrosty
did you wait for VVT to kick in before driving it?
2013 Whiteout 6AT FR-S | Perrin Inlet Tube + 2.75" CAI | OpenFlash Header | P&L Catback | 4.88 Final Drive | Dialed in OFT 2.0x Stage 2 E85 | 18x8 Enkei Raijin + 225/40 Michelin Pilot Super Sport | 17x7 Stock + 215/45 Michelin X-Ice Xi-2
phrosty is offline   Reply With Quote
Old 08-17-2014, 08:10 PM   #3
v86
Kid Gt86
v86's Avatar
Yes, I did indeed.
Old 08-17-2014, 08:55 PM   #4
invaliduser
Drives: 2017 86
u need to do a 3rd gear 2k to redline pull.
invaliduser is offline   Reply With Quote
Old 08-18-2014, 10:20 AM   #5
lucid215
if you just reflashed then tried to do a log the car will feel sluggish. you gotta give it some miles to relearn the new rom
lucid215 is offline   Reply With Quote
Old 08-18-2014, 06:03 PM   #6
v86
Kid Gt86
v86's Avatar
I realize that i have to do have to give the car some time... which is why i tried to decide speeding up some of the process by using Vishnu Secret ECU trick.
With that being said I'll be doing a 3rd gear pull by tomorrow so' we could all elaborate on the results
Old 08-18-2014, 07:15 PM   #7
steve99
Perrin crank pulley
Perrin drop in
Crawford BPB
Stage 1 OFT tune
Log looks fine LTFT around 3% or less , if you log Knock correction and FLKC instead of VVT intake and exhaust would be better and log IAM instead of MAF V.
however KC Learned not showing any signs of knock.
As other said a WOT 3rd gear run included 2000-redline would be good.
ECU learns quite quickly (in minutes) especially if MAF scaling is good and their is no knock its got very little to learn, you look like your in that category.
Old 08-18-2014, 08:29 PM   #8
Boofneenee
Go-Kart Enthusiast
Boofneenee's Avatar
Drives: Toyota Scion FRS
Perrin crank pulley
Perrin drop in
Crawford BPB
Stage 1 OFT tune
make sure your wide open throttle as well.
FRS
Current mods: K&N air filter, OFT, OFH, berk high flow cat front pipe, Q300 exhaust, lighter wheels
Boofneenee is offline   Reply With Quote
◙◙◙ The "Keep Your Car Running Healthy" Thread | Real Auto Dynamics ◙◙◙ Kevin@RAD Announcements, Contests, Giveaways 36 06-07-2013 02:26 PM
