Drives: BRZ 2013
Feedback on Hawk ER-1 pads ?
Good day,
I’d be looking to see if anyone has had experience driving the new Hawk ER-1 endurance pads on track, and if possible how they may compare with the Ferodo ds1.1, which I ran last year on hpde, and was very satisfied with. Mu seems quite similar between the two compound. I found very little on the web on the new ER-1 besides Hawk’s content. Thanks |
#2 | |
Drives: Subaru BRZ / Toyota 86 Experts
There are many other compounds available on the market, but each compound has its own unique characteristics which require you to use them differently. Once you find the one that gives you the largest range of use, that's the one you'll come to like. |
Drives: '22 BRZ
They're similar to the DS1.11 but a bit less torque. Sorta like a Pagid RSL29 too.
#4 | |
Drives: BRZ 2013
#5 | |
Drives: BRZ 2013
So I thought I would offer some early feedback of my first experience using the new hawk ER-1 endurance pads on my Turbo BRZ on my first track/hpde day of the season. I can’t talk about longevity yet, however I can offer some initial feedback relative to the Ferodo DS 1.11 I used last season. Both were used with the same car and on the same track, a high speed circuit with 20 or 25mins sessions in an intermediate run group, with the stock (non PP) calipers and RBF600/660 oil. Pads were bedded in accordance with the manufacturer guide before each day. I used the DS1.11s with PS4S tires and the ER-1s with both PS4S and NT01s. I have no sponsorship whatsoever so (unfortunately for me I guess…), I buy all my consumables on my own dime… so I guess the feedback will not be financially biased… :-) although these are early first impressions on just 1 day (about 120mims) of track time, and one season apart, so not back to back.
Overall so far I found the ER-1s to be at least as capable as the DS1.11. Both gave me very reliable and steady breaking with no fading whatsoever throughout the day. The ER-1s seem to provide a higher Mu which allowed me to shorten my breaking distances, while providing ease of modulation such that I could control my braking with confidence. The first session was a bit less confidence inspiring however I was scrubbing the brand new NT01s and things really improved as the system heated up. On the PS4S, sometimes I felt the DS1.11 had to be feathered carefully on long high speed braking zones to avoid lockup/ABS kicking in, in comparison the ER-1s seemed to be a little easier to modulate once at operating temperature. Trying the ER-1s with the NT01s, I was expecting to feel the limit of the stock calipers, however so far so good - the brakes were steady, consistent and solid all day long, and the added grip allowed me to significantly shorten my braking zones, to a point I need now to adjust my braking points since I now am braking much too soon, and able to carry more speed in the turns. All this to say that the first impressions on the ER-1s are very positive, and seem a very strong contender to the ds1.11s. As I said in my earlier post, I really liked the DS1.11s, but wanted to give the ER-1s a try since they are more readily available in my area and less expensive relative to the DS1.11s. They needed to be warmed-up a bit more than the ferodos to perform well, but once heated up after the first session they performed flawlessly and with great stopping power and modulation all day long. I will be able to report more on durability later on in August … Cheers |
| The Following 3 Users Say Thank You to falcon_wizard For This Useful Post: |
Drives: 18 Brz (Sold) / 22 BRZ / 13 BRZ
Reviving this thread. I am planning on going er-1 on rear axles. Paired with CSG CE2 on fronts.
As soon as i have some tracks on the belt with updated system, will let everyone know (or if the plan changes). |
| The Following User Says Thank You to Stonehorsw For This Useful Post: | RT-BRZ (07-07-2025) |
| FS: OEM wheels, HAWK HPS front and rear brake pads, OEM brake pads, TYC colins tails | oppiee | Canada Classifieds | 4 | 10-07-2019 05:27 PM |
| Hawk Pads (DTC-30/HP Plus) | justint5387 | Brakes, Suspension, Chassis | 2 | 08-12-2019 08:11 PM |
| FS: Hawk HPS pads | Xevuhtess7 | Brakes, Suspension, Chassis | 0 | 10-24-2017 05:32 PM |
| New Hawk pads out | Grip Ronin | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 10 | 11-13-2014 08:25 PM |
