Old 11-25-2022, 02:06 AM   #1
Brzerker
Brzerker's Avatar
Drives: World Rally Blue BRZ
High pitched noise when cold starting
Hi all,
Recently I've noticed a high pitched noise coming from the AC compressor area during cold starts. I'm not sure if it's coming from the high pressure fuel pump or the AC compressor.
Video of sound during cold start
https://streamable.com/e/j8ayq8
Hopefully someone here has an idea what could be the cause.
Thanks!!!!
Brzerker is offline   Reply With Quote
Old 11-25-2022, 02:21 AM   #2
Ultramaroon
not playing cards
Ultramaroon's Avatar
It's the belt slipping over your alternator pulley. Get a fresh accessory belt or clean all the tiny pieces of sand stuck in the grooves of your current one.
Old 11-25-2022, 04:18 AM   #3
Brzerker
Brzerker's Avatar
Thanks! Will take a look at the belt. Weird thing is the sound goes away when the car warms up.
Old 11-25-2022, 09:13 AM   #4
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
While the belt is off, spin the idler pulleys and check them for free play. A new belt might be a good idea. A belt conditioner product might help the old belt. Sand in your groove can definitely be a problem.
Old 11-25-2022, 10:42 AM   #5
As the belt warms up it becomes "softer" and seats better in the pully which makes the noise go away.
Old 11-25-2022, 03:04 PM   #6
Ultramaroon
not playing cards
The sound goes away when the alternator is finished doing most of its work. First the battery dumps a bunch of energy into the starter, then the alternator works hard to dump all that energy back into the battery.
Crank on the headlights, step on the brakes for those lights, and set the cabin blower to high. Does the belt squeak over the alternator pulley then?
Belt dressing is evil. It just ruins the belt.
For some reason on this car, sand does settle into the belt grooves. I'm still on the original and I've cleaned it twice by carefully picking out the grains with a needle.
Old 11-25-2022, 03:10 PM   #7
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
I've got 115,000km on the OEM belt. I'm used to changing these more often on other cars. :Lol:
Old 11-25-2022, 03:38 PM   #8
A cold belt will always squeal where a warm one won’t regardless of load.
Old 11-25-2022, 05:36 PM   #9
Ultramaroon
not playing cards
I agree that cold temperature exacerbates the issue. It is not the main reason the belt slips over an alternator pulley immediately after startup.
Another way to test but might cause a MIL. While it's squealing, disconnect the regulator connector. Won't hurt anything. Alternator immediately becomes an idler pulley.
Old 11-26-2022, 06:15 PM   #10
humfrz
Says you. But, back in the day, it was very important. As a kid, that was part of my job. Yep, then I would lay grasshoppers on the belt and see if they would jump off before they would reach a pully -
Old 11-26-2022, 06:17 PM   #11
humfrz
Says you. But, back in the day, it was very important. As a kid, that was part of my job. Yep, then I would lay grasshoppers on the belt and see if they would jump off before they would reach a pulley -
Old 11-26-2022, 06:22 PM   #12
Ultramaroon
not playing cards
I had no idea that grasshoppers make a good belt dressing.
Old 11-26-2022, 06:40 PM   #13
humfrz
They didn't - that's the reason my grandpa made me quit doing it. -
Old 11-29-2022, 01:30 AM   #14
Brzerker
Brzerker's Avatar
An update on the issue.
Took the belt off to inspect and found a bigger issue, leaking coolant! I think the belt might have been tainted with coolant which was causing the squeaks. My local mechanic swapped the belt and broken plate, and all seems to be good for now. Car is around 180k km (~110k miles)
btw, does anyone have a name for what this plate is called?
Radiator fans making high pitched snap noise upon them starting up scottryan Issues | Warranty | Recalls / TSB 4 08-23-2020 09:14 PM
High pitched noise when lightly braking brsaresmgs Issues | Warranty | Recalls / TSB 7 11-29-2017 12:22 AM
Turn signal stalk making weird high pitched noise. FRS-Learner Issues | Warranty | Recalls / TSB 6 11-07-2015 08:54 PM
high pitched noise when clutch is engaged ( video attached) jotig Issues | Warranty | Recalls / TSB 9 07-05-2015 09:22 PM
High Pitched Noise, Engine Off TheLaughingMan Issues | Warranty | Recalls / TSB 10 01-04-2014 05:25 PM
