| BRZ Second-Gen (2022+) — General Topics General topics for the second-gen BRZ |
Drives: 2023 brz limited 6mt red
Tpms set point?
23 brz limited. The tire recommendation is 35psi cold and the tpms sensor shows low pressure light at 34psi. Is there a way to set it at 30 or 32 for low pressure or why the heck would it be set 1psi under recommended? which is ridiculous.
I understand I could set it a few psi higher but with weather fluctuations +\-40 degrees is a gamble and 51 is max but I don’t care for 40ish psi hot ride quality |
Drives: 2022 BRZ Manual Ice Silver Metallic
my light never gets on even as low as 25cold. For me it only lit up when it detected a leak/flat, so I would check for that.
The Dictater
Drives: '13 Red Scion FRS
How are you reading your pressures?
Could be a sensor or pressure gauge malfunction.
If a picture is worth a thousand words, a model is worth ten thousand pictures.
Also: "Build Thread" |
Drives: 2023 BRZ Limited
After the tires were at the proper pressure, was the "baseline" programmed in? If not, it would explain the behavior that you are seeing.
If not, make sure the tires are at the proper pressure, then reset the TPMS. |
Drives: '22 BRZ
I think my light only came on when I got down to about 25 or so, driving home after an event. And on other cars I've seen the light come on with differences as small as 3-4psi from one tire to another.
| The Following User Says Thank You to eyeballs For This Useful Post: | Spuds (11-16-2022) |
The dealer programmed the baseline. I haven’t reset anything I was under the impression tpms sensors have a predetermined psi set point that cannot be adjusted and or curious if other people had issues or what their set point is for low psi warning.
The Dictater
I think the sensors themselves just output a value representing the tire pressure. It would be whatever computer in the car that determines what is too low. If the dash and air guage match, then the warning light might be adjustable with techstream.
Dealer should be able to set it lower if that's the case.
#10 | |
#11 |
Sr. Spiritual Advisor
Drives: 2023 BRZ Premium
In my experience, the alert was displayed once the tires were below 26 PSI, and the very insistent and annoyingly non-dismissable alert was up until they hit 30+ PSI. Interestingly, the pressures were marked yellow, yet the alert was not up when it was very cold outside, though, so perhaps it changes its behavior per outside temps.
'23 Subaru BRZ Premium Manual (Track Build Thread)
'22 Ford F150 Lariat Powerboost SuperCrew 6'5" 4x4 '21 Tesla Y Long Range AWD '19 Corvette Z06 Z07 (Track Build Thread) |
| The Following User Says Thank You to X25 For This Useful Post: | timurrrr (11-17-2022) |
#12 | |
#13 |
Thanks all for responses….
#14 |
The Dictater
NP. Please report back here after you bring it in to let us know if that fixed it.
| Broke a TPMS sensor, process with ATEQ Quickset and new TPMS Sensor? | Anthonyc77 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 6 | 03-19-2018 08:57 PM |
| FS- TPMS System for cars without TPMS- New | solort | Wheels and Tires | 1 | 03-16-2017 11:12 PM |
| NEED HELP!! TPMS light on. with TPMS installed on aftermarket rims+tires | Figo | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 9 | 09-23-2013 08:11 AM |
| Changed to new wheels w/o TPMS, car still thinks I have TPMS sensors? | Ahz | Issues | Warranty | Recalls / TSB | 9 | 11-06-2012 08:25 AM |
