Old 11-15-2022, 10:27 AM   #1
ClaytonG
Drives: Car Enthusiast trying to learn more
Question Dream BRZ Build..Suggestions
I want a 2016 brz to build good for daily driving but I want a nice sound but not too much so it wakes the entire neighbourhood. Not only that but I want that power to match the sound because what's the point of having a car that sounds good but has no power to match it? I want it for daily driving but I wouldn't mind ripping it around the track. Any suggestions??
Subaru BRZ/FRS/86 2016 - 20,000.00 (rough estimate)
Wheels
18x8.5 30 5 x100 TE 37- $5000.00
225 /40/r18
0r
18x7.5 5x100 Prodrive GC-010E forged rims
Brakes
Engine
FBM Fa20 Stage 2 Head Package- $2,995.00
FBM Competition port and Polish intake and exhaust ports:
- Competition Valve Job
- Resurfaced and Clean and assembly
- Ferrea 6000 series Valve
- Ferrea Single Valve Springs (+1mm oversized)
- Ferrea Tool Steel Retainers
- Ferrea Seat locators and new valve stem seals
Stage 2 heads:
Stock Exhaust Flow @ .500 lift = 170
FBM Stage 1 & 2 Exhaust Flow @ .500 = 220
Stock Intake Flow @ .500 lift = 280
FBM Stage 1 & 2 Intake Flow @ .500 = 305
Stage 1 Cams:
Full Blown Stage 1 FA20 Cams- $1,395.00
Transmission
Forced Induction and Supporting Mods
SUSPENSION:
Front and Rear Sway Bar Kit Whiteline BSK020 - $494.82
Whiteline adjustable end links (Front)- $123.71
Whiteline adjustable end links (Rear)-
Whiteline Center/Bump steer correction Kit - $352.90
Intake
Perrin Performance Cold Air Intake Black BRZ - $420.00
Perrin Performance Inlet Hose Black for 13-16 BRZ - $120.00
Exhaust
Performance Accessories
???fuel pump
???fuel kit
????Belt and Pullets
??? Cooling lines
Body Kits and Accessories
Interior
Perrin Drift Button - $31.45
AEM boost Gauge
AFR Gauges
Exterior
Valenti GOLD edition 4th brake light$300.00
APR Carbon Fiber Mirror- $383.35
TOTAL: $31,616.23
ClaytonG is offline   Reply With Quote
Old 11-15-2022, 10:45 AM   #2
Pat
Pat's Avatar
Drives: 2023 BRZ
Originally Posted by ClaytonG View Post
Any suggestions??
Buy a Corvette.
Old 11-15-2022, 10:53 AM   #3
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
Sounds like a great plan for a DD.
Old 11-15-2022, 11:52 AM   #4
Apolllo
Drives: 2018 Subaru BRZ Limited
Sounds like you are wanting two completely different things.
500-800HP Track Car != Daily Driver, no matter what you do.
What kind of racing are you planning to do? Have you raced before? Looking at your build sheet, you have little to no suspension upgrades, but a ton of performance upgrades like you plan to just drag race.
As much as you probably don't want to hear it, I would suggest starting out small. Buy the car, take it to the track stock and learn how to drive it, then slowly mod it. No need to go balls to the wall with a fully built turbo right out of the gate.
Apolllo is offline   Reply With Quote
Old 11-15-2022, 12:25 PM   #5
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Don't bother with a built engine or heads, cams. Get the turbo kit, run at 10-12psi and it's going to be great.
JDL EL Recirc manifold, Boostlab BL58x Turbo w/ T51R, 17x9 ARC-8, IAG block
Old 11-15-2022, 12:40 PM   #6
dpfarr
Drives: BRZ ts
I like my car but your budget is a 20k car w 27k added to it. Not including labor, maybe it’s your own.
You checked out a Supra?
dpfarr is offline   Reply With Quote
Old 11-15-2022, 03:01 PM   #7
"500 hp is a good start I don't want anywhere above 800hp" was all I needed to read.
Ask your parents for a Ferrari for your 17th birthday.
Old 11-15-2022, 05:49 PM   #8
alphasaur
friendly
Drives: 17' 86
lmao
Seek comfort in discomfort.
alphasaur is offline   Reply With Quote
Old 11-15-2022, 08:05 PM   #9
Grady
Grady's Avatar
looks like you have a realistic approach. I would budget an additional 20% for the unknown. You can make it reliable but it will take time. Don’t expect to put it together and it be reliable you will have to work out some bugs. One of the issues is you are getting above the transmission capabilities for reliability.
Grady is online now   Reply With Quote
Old 11-15-2022, 09:14 PM   #10
villainous_frx
Off to the track!
villainous_frx's Avatar
Drives: '14 Lava 86, '13 WRB BRZ
Get the car first, focus on a build second imo. I do want to point out that you're missing supporting mods for such a high powered venture; oil cooling, clutch, potentially transmission, to name a few.
villainous_frx is offline   Reply With Quote
Old 11-15-2022, 10:46 PM   #11
shiumai
shiumai's Avatar
Drives: 2013 DGM BRZ, 2020 C8 Corvette
Originally Posted by Pat View Post
Buy a Corvette.
This. A used C6 Z06 is right in that price range.
shiumai is offline   Reply With Quote
Old 11-16-2022, 05:18 AM   #12
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
Same.
Anyone remember Nick Hogan???
OP sounds like him.
Old 11-16-2022, 10:44 AM   #13
Falkon240
Falkon240's Avatar
Drives: 2013 FRS
This is exactly where I thought this would go.
IG
2013 Scion FR-S
2022 Chevrolet Colorado ZR2 Bison
1998 Nissan 240SX KA24DET
Falkon240 is offline   Reply With Quote
Old 11-16-2022, 09:57 PM   #14
soundman98
ProCrastinationConsultant
soundman98's Avatar
that's a lot of money just to run to the gas station for smokes every once in a while.
daily driver, dream project, subaru brz, track build
MAAAD86's dream build Maaad86 Member's Car Journals 42 12-08-2015 02:12 AM
Scion FRS - Track Dream build - under $20k - Normally aspirated philooo Tracking / Autocross / HPDE / Drifting 85 08-07-2015 10:16 PM
Is this project doable? (My dream build) Taisenki Cosmetic Modification (Interior/Exterior/Lighting) 17 10-29-2014 11:24 PM
Morpheus, Scion dream Build. Supercharged FR-S by TuneCast scionsalesjay Member's Car Journals 51 07-07-2014 12:05 PM
Dream.Build.Drive TylerLieberman Other Vehicles & General Automotive Discussions 3 05-28-2014 11:53 PM
