| BRZ First-Gen (2012+) General Topics All discussions about the first-gen Subaru BRZ coupe |
Drives: Car Enthusiast trying to learn more
I want a 2016 brz to build good for daily driving but I want a nice sound but not too much so it wakes the entire neighbourhood. Not only that but I want that power to match the sound because what's the point of having a car that sounds good but has no power to match it? I want it for daily driving but I wouldn't mind ripping it around the track. Any suggestions??
Subaru BRZ/FRS/86 2016 - 20,000.00 (rough estimate) Wheels 18x8.5 30 5 x100 TE 37- $5000.00 225 /40/r18 0r 18x7.5 5x100 Prodrive GC-010E forged rims Brakes Engine FBM Fa20 Stage 2 Head Package- $2,995.00 FBM Competition port and Polish intake and exhaust ports: - Competition Valve Job - Resurfaced and Clean and assembly - Ferrea 6000 series Valve - Ferrea Single Valve Springs (+1mm oversized) - Ferrea Tool Steel Retainers - Ferrea Seat locators and new valve stem seals Stage 2 heads: Stock Exhaust Flow @ .500 lift = 170 FBM Stage 1 & 2 Exhaust Flow @ .500 = 220 Stock Intake Flow @ .500 lift = 280 FBM Stage 1 & 2 Intake Flow @ .500 = 305 Stage 1 Cams: Full Blown Stage 1 FA20 Cams- $1,395.00 Transmission Forced Induction and Supporting Mods SUSPENSION: Front and Rear Sway Bar Kit Whiteline BSK020 - $494.82 Whiteline adjustable end links (Front)- $123.71 Whiteline adjustable end links (Rear)- Whiteline Center/Bump steer correction Kit - $352.90 Intake Perrin Performance Cold Air Intake Black BRZ - $420.00 Perrin Performance Inlet Hose Black for 13-16 BRZ - $120.00 Exhaust Performance Accessories ???fuel pump ???fuel kit ????Belt and Pullets ??? Cooling lines Body Kits and Accessories Interior Perrin Drift Button - $31.45 AEM boost Gauge AFR Gauges Exterior Valenti GOLD edition 4th brake light$300.00 APR Carbon Fiber Mirror- $383.35 TOTAL: $31,616.23 Last edited by ClaytonG; 11-24-2022 at 10:39 AM. Reason: Update |
#2 |
Drives: 2023 BRZ
Director of Rocky Mountain 86CUP
| The Following 14 Users Say Thank You to Pat For This Useful Post: | alphasaur (11-15-2022), bucketfoot (11-15-2022), Code Monkey (11-15-2022), DarkPira7e (11-15-2022), Jdmjunkie (11-15-2022), pope (11-27-2022), RedReplicant (11-19-2022), RToyo86 (11-24-2022), soundman98 (11-16-2022), Spuds (11-18-2022), Tcoat (11-15-2022), The Red One (11-15-2022), whataboutbob (11-15-2022), x808drifter (11-16-2022) |
#3 |
Famous Potatoes
Drives: '15 ultramarine
Sounds like a great plan for a DD.
#4 |
Drives: 2018 Subaru BRZ Limited
Sounds like you are wanting two completely different things.
500-800HP Track Car != Daily Driver, no matter what you do. What kind of racing are you planning to do? Have you raced before? Looking at your build sheet, you have little to no suspension upgrades, but a ton of performance upgrades like you plan to just drag race. As much as you probably don't want to hear it, I would suggest starting out small. Buy the car, take it to the track stock and learn how to drive it, then slowly mod it. No need to go balls to the wall with a fully built turbo right out of the gate. |
| The Following User Says Thank You to Apolllo For This Useful Post: | x808drifter (11-16-2022) |
#5 |
Rust bucket enthusiast
Don't bother with a built engine or heads, cams. Get the turbo kit, run at 10-12psi and it's going to be great.
| The Following User Says Thank You to DarkPira7e For This Useful Post: | Jdmjunkie (11-15-2022) |
#6 |
Drives: BRZ ts
I like my car but your budget is a 20k car w 27k added to it. Not including labor, maybe it’s your own.
You checked out a Supra? |
#7 |
"500 hp is a good start I don't want anywhere above 800hp" was all I needed to read.
Ask your parents for a Ferrari for your 17th birthday.
| The Following 10 Users Say Thank You to Tcoat For This Useful Post: | alphasaur (11-15-2022), Apolllo (11-15-2022), JD001 (11-19-2022), Jdmjunkie (11-15-2022), pope (11-17-2022), RedReplicant (11-19-2022), RToyo86 (11-24-2022), soundman98 (11-16-2022), Spuds (11-18-2022), x808drifter (11-16-2022) |
#8 |
friendly
Drives: 17' 86
lmao
Seek comfort in discomfort.
#9 |
looks like you have a realistic approach. I would budget an additional 20% for the unknown. You can make it reliable but it will take time. Dont expect to put it together and it be reliable you will have to work out some bugs. One of the issues is you are getting above the transmission capabilities for reliability.
#10 |
Off to the track!
Drives: '14 Lava 86, '13 WRB BRZ
Get the car first, focus on a build second imo. I do want to point out that you're missing supporting mods for such a high powered venture; oil cooling, clutch, potentially transmission, to name a few.
| The Following 3 Users Say Thank You to villainous_frx For This Useful Post: |
#11 |
Drives: 2013 DGM BRZ, 2020 C8 Corvette
My DGM BRZ vid: https://www.youtube.com/watch?v=0OL9OhxexAA
My car journal thread: http://www.ft86club.com/forums/showthread.php?t=43402 |
#12 |
LMGTFY
Drives: 13 FRS, 91 Miata
#13 |
Drives: 2013 FRS
This is exactly where I thought this would go.
| The Following User Says Thank You to Falkon240 For This Useful Post: | Ace23_BRZ (11-29-2022) |
#14 |
ProCrastinationConsultant
that's a lot of money just to run to the gas station for smokes every once in a while.
| The Following User Says Thank You to soundman98 For This Useful Post: | Jdmjunkie (11-16-2022) |
| Tags |
| daily driver, dream project, subaru brz, track build |
| MAAAD86's dream build | Maaad86 | Member's Car Journals | 42 | 12-08-2015 02:12 AM |
| Scion FRS - Track Dream build - under $20k - Normally aspirated | philooo | Tracking / Autocross / HPDE / Drifting | 85 | 08-07-2015 10:16 PM |
| Is this project doable? (My dream build) | Taisenki | Cosmetic Modification (Interior/Exterior/Lighting) | 17 | 10-29-2014 11:24 PM |
| Morpheus, Scion dream Build. Supercharged FR-S by TuneCast | scionsalesjay | Member's Car Journals | 51 | 07-07-2014 12:05 PM |
| Dream.Build.Drive | TylerLieberman | Other Vehicles & General Automotive Discussions | 3 | 05-28-2014 11:53 PM |
