Old 11-14-2022, 02:22 PM   #1
X25
Sr. Spiritual Advisor
X25's Avatar
Drives: 2023 BRZ Premium
Mini DIY: Zip-tie (GoPro) bar mount for large bars!
If you're using a harness bar like BK's for our cars, you will realize that the center section of the bar is too wide for any off-the-shelf bar mount to work. I ended up making a mount with little to no cost.
The key is to find appropriately sized zip ties that you can fit within the rails of the GoPro mount. I inserted one side of the top mount piece to its rail first, and then forced the other side.
Align your zip ties before you fully insert the top mount, since you won't get to move it once it's in.
Ready to install
You probably don't need to use the adhesive bottom, but why not; it would reduce vibrations and movements at least..
Done!
'23 Subaru BRZ Premium Manual (Track Build Thread)
'22 Ford F150 Lariat Powerboost SuperCrew 6'5" 4x4
'21 Tesla Y Long Range AWD
'19 Corvette Z06 Z07 (Track Build Thread)
X25 is offline   Reply With Quote
GoPro Mount - Ansix Auto Ansix Auto Interior Parts (Incl. Lighting) 7 04-30-2025 12:51 AM
Tackform Headrest Mount for GoPro Code Monkey Miscellaneous 2 01-06-2019 08:21 PM
GOPRO MOUNT Jonathan Le DIY (Do-It-Yourself) Guides 1 06-09-2017 09:42 PM
DIY: GoPro tow hook mount BatStig DIY (Do-It-Yourself) Guides 20 07-19-2015 04:54 AM
DIY: Making a GoPro camera mount with a GrimmSpeed front plate mount PMok DIY (Do-It-Yourself) Guides 2 06-11-2013 10:58 AM
