Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 2nd Gens: GR86 and BRZ > GR86 General Topics (2nd Gen 2022+ Toyota 86)
GR86 General Topics (2nd Gen 2022+ Toyota 86) General topics for the GR86 second-gen 86
Old 11-07-2022, 01:35 AM   #1
shionjisama
Drives: 2022 GR86
Thoughts on ordering suspension from gr86 cup car?
I'm new to this site, I read a lot of posts but this is the first time for me to ask a question.
Does anybody have experience with this suspension set developed by TRD?
TRD
COIL SPRINGS AND SHOCK ABSORBERS for GR86 Cup Car Basic (MS250-18006 + MS260-18006)
The price is about 2700 usd if you order it from Japan.
I'm currently choosing from this and a decent coilover set. I know coil-over will typically give you more adjustability but I don't think I will do a better job in terms of tuning the suspension than those engineer's how developed the actual car, or the racing department behind them.
I don't care if it gonna be a harsh ride, I assume it will be super aggressive, as long as it won't be easily broke on normal road conditions. But will it?
Interestingly, in Japan domestic market, this set is not associate with 86 cup car at all, it just has name: GR suspension.
Any thoughts?
shionjisama is offline   Reply With Quote
Old 11-07-2022, 04:32 AM   #2
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
Yeah...
That is not how most high end OTS parts let alone coil-overs work.
The consumer is the deciding factor and therefore most are not adjusted at all because driving style plays into it alot.
There are exceptions. TRD/GR/Whatever they decide next is not one of them.
Either
1. Leave the car how it is.
2. RCE Yellow drop springs and B6/8 dampers.
Seeing as you know as much as you do I do not recommend jumping to adjustable coil-overs.
The Following 3 Users Say Thank You to x808drifter For This Useful Post:
ric342 (11-09-2022), spike021 (11-08-2022), Spuds (11-07-2022)
Old 11-07-2022, 09:00 AM   #3
_____That_-_GUY_____
Drives: 2022 GR86
What's your goals for the car? Is a dedicated track car, mixed street & track, mostly street with some track, or just a street car.
I wouldn't go with the CUP suspension unless it's mostly a track car. Higher end coilovers may still be a better option. I don't know anything about the CUP suspension. Wonder what the spring rates are.
_____That_-_GUY_____ is offline   Reply With Quote
The Following User Says Thank You to _____That_-_GUY_____ For This Useful Post:
Spuds (11-07-2022)
Old 11-07-2022, 12:40 PM   #4
Racecomp Engineering
That is not the suspension used on the GR86 cup car of the US series run by SRO.
- Andrew
The Following 2 Users Say Thank You to Racecomp Engineering For This Useful Post:
DylanJZA (11-08-2022), x808drifter (11-08-2022)
Old 11-07-2022, 03:32 PM   #5
Drives: 2022 GR86
- Andrew
I tried looking for more in depth info on the SRO GR86 cup car modifications. Only found just some surface level info.
Do you know if there is a complete build list, with technical specs?
Old 11-07-2022, 06:07 PM   #6
This is all that's public right now as far as I know.
- Andrew
The Following User Says Thank You to Racecomp Engineering For This Useful Post:
ROFL it's Waffle (11-10-2022)
Old 11-07-2022, 06:11 PM   #7
NLSP
NLSP's Avatar
Drives: 2014 Ultramarine FR-S
https://trd-motorsports.jp/gr86cupca...uspension.html
This GR86 Cup Car Basic suspension appears to be a revised version of something they offered for first gen and is technically also an adjustable coilover; 40-way adjustable damping and height adjustable (-15mm out of the box). No camber plates/adjustments are included (can reuse OEM top mounts) and no spring rate published (again).
The text in the middle of the page briefly speaks to the intended purpose of the setup - "...it has a high-rate setup that focuses more on circuit driving, and has improved steering stability in the high-speed range such as race use."
Found a Japanese user review, but they didn't really speak to how it drives:
https://minkara.carview.co.jp/userid...648/parts.aspx
And I only know of one user stateside that had it on their first gen, but the thread is 100+ pages, not sure if they ever talked about how the suspension feels:
https://www.ft86club.com/forums/showthread.php?t=40726
Overall, I feel like it's a gamble whether you'll like it (Japanese roads/tracks are said to be glass-smooth). And if you run into a problem, any support/warranty/parts/rebuild would be a hassle since there's no stateside support for it.
NLSP is offline   Reply With Quote
Old 11-07-2022, 07:33 PM   #8
VoltsFRS2013
VoltsFRS2013's Avatar
Drives: 2022' GR86 Premium 6MT
Just my $0.02 but $2,700 can get you a bitchin' set of coilovers.
Would not see any reason to go for cup suspension given the aftermarket options out there that will probably arguably be better for your application.
22' Toyota GR86 - Trueno Blue - M/T (CURRENT)
18' Toyota 86 GT Black - Moonslate Gray - M/T (SOLD)
13' Scion FRS - Ultramarine - A/T (SOLD)
VoltsFRS2013 is offline   Reply With Quote
Old 11-07-2022, 08:46 PM   #9
soundman98
ProCrastinationConsultant
soundman98's Avatar
imo, the only reason to run the cup suspension is if you're participating in the cup series.
Old 11-07-2022, 10:28 PM   #10
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
FYI the Cup suspension in North America is fairly high end...
https://jrishocks.com/pages/about
The Following 2 Users Say Thank You to mav1178 For This Useful Post:
DylanJZA (11-08-2022), Racecomp Engineering (11-08-2022)
Old 11-08-2022, 01:49 PM   #11
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
One other thing to consider with these would be ease/cost of getting them serviced. What kind of support is offered for non series participants?
Old 11-08-2022, 04:45 PM   #12
TommyW
TommyW's Avatar
Drives: '13 Whiteout
- Andrew
Surprised it has traction control
Old 11-08-2022, 09:40 PM   #13
Fancy traction control and fancy ABS.
- Andrew
Old 11-08-2022, 09:45 PM   #14
TommyW
TommyW's Avatar
- Andrew
Interesting. How invasive is the TC?
2022 GR86 stock suspension ozafar Brakes, Suspension, Chassis 1 02-02-2023 03:12 PM
San Diego: 2022 GR86 OEM Premium GR86 Rims GRime86 Wheels and Tires 3 12-10-2022 04:52 PM
GR86 GR suspension Master Jedi Suspension | Chassis | Brakes -- Sponsored by 949 Racing 26 09-03-2022 07:25 AM
GR86 In R7 of the Toyota Gazoo Racing GT Cup + GR86 coming to Grand Turismo Sport Blighty GR86 General Topics (2nd Gen 2022+ Toyota 86) 28 07-18-2021 03:38 PM
Ordering a FR-S becauseracecar1 Scion FR-S / Toyota 86 GT86 General Forum 19 03-27-2014 01:24 PM
