Old 11-05-2022, 06:09 PM   #1
Muskoka800
Drives: 2016 Scion FRS Release Series 2#439
Engine Leveler?
A ? for those who have lifted the FA20 out of their 86.
Did you use/need an engine leveller for your hoist?
And did you pull the engine with or without the manual tranny still attached?
I have no-issue removing the tranny first but wonder if I should invest in a leveller to ease removal and post rebuild install.
Thanks in advance for your educated reply.
Edelbrock S/C with CSG 94 & 91 maps
TRD Short Shifter, CTS-V/EvoX Brembos
Ohlin’s R&T Dampers, Hotchkis F/R Bars, Blox LCA & Toe Arms
235F/245R Conti ECS on TRD/Enkei wheels (street),
245/40 sq. ECF on 17x8 720Form GTF2 wheels (track)
Muskoka800 is offline   Reply With Quote
Old 11-05-2022, 07:58 PM   #2
Ultramaroon
not playing cards
Ultramaroon's Avatar
In for the discussion. Do you think you might pull other engines in the future? I use two together but transverse engines can be real bitches. I haven't yet had to pull my fa20.
Old 11-05-2022, 10:52 PM   #3
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
I used a leveler. Worth the Harbor Freight investment. Sold it for almost what I paid.
Old 11-06-2022, 09:26 AM   #4
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Yes, worthwhile for tilting. Left transmission in place
JDL EL Recirc manifold, Boostlab BL58x Turbo w/ T51R, 17x9 ARC-8, IAG block
Old 11-06-2022, 08:45 PM   #5
Joethefo
Drives: 13 BRZ
Engine levelers are great especially if you'll be pulling the engine or many others frequently.
One thing I've done in the past when my leveler wasn't available or being used else where, was to use a ratchet strap(s) to adjust the angle of the engine. Obviously just be careful you don't have it attached somewhere that could break, or where the strap could get cut and tear causing the engine to swing or move.
Joethefo is offline   Reply With Quote
Old 11-06-2022, 11:18 PM   #6
e1_griego
e1_griego's Avatar
Drives: Many
I don't usually use one for FA/FB motors.
They usually come out pretty flat already.
e1_griego is offline   Reply With Quote
Old 11-11-2022, 12:13 PM   #7
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
If you are leaving the trans in place, coming out it doesn't matter. Going in it helps quite a bit.
Pulling with trans attached, 100% would want a leveler. It would be so much easier.
The Following User Says Thank You to NoHaveMSG For This Useful Post:
x808drifter (11-13-2022)
14 FRS COMPLETE FA20 ENGINE 13-16 2.0L VIN N 5th DIGIT ENGINE MOTOR 120k mgp Engine, Exhaust, Bolt-Ons 5 07-13-2021 06:45 PM
Will I get a check engine light on if the engine bay has a direct injection failure? Astroboy Engine, Exhaust, Transmission 7 03-29-2014 07:16 PM
headlight leveler Kfresh23 CANADA 10 01-30-2014 12:22 PM
WTT: BRZ headlight leveler trim (modded for gauges) antlers Interior Parts (Incl. Lighting) 0 08-09-2013 10:31 PM
Engine sputtering while idling with check engine light flashing, WTF speedy racer Scion FR-S / Toyota 86 GT86 General Forum 15 08-27-2012 07:50 AM
