Old 11-05-2022, 05:31 AM   #1
GTwice
Drives: 2017 BRZ
2018 BRZ key lock question
Hello
Quick question: is the key lock (barrel) in the trunk the same as the one in the door on a 2018 BRZ? I mean, some brands have a shorter barrel in the trunk and they don't actually use the whole key to open (you only insert the key halfway and turn).
Asking because it's much easier to remove the lock from the trunk than from the door and I need to get a new emergency key cut as the previous owner lost both.
GTwice is offline   Reply With Quote
Old 11-06-2022, 04:24 PM   #2
WildCard600
WildCard600's Avatar
Drives: 2020 86
Originally Posted by GTwice View Post
Hello
I checked my 86 and the key appears to go the same depth in the trunk lock as it does on the door. I don't know if the cylinders are identical since the valet key for mine will only open the door and not the trunk so it seems like there is something different about the trunk lock.
I have a regular keyed ignition and not push to start so I don't know how that might affect things either.
WildCard600 is offline   Reply With Quote
Old 12-12-2022, 06:41 AM   #3
GTwice
Drives: 2017 BRZ
If anyone is ever in the same situation as me: you can get the key cut to the trunk lock, it will also open the door lock.
Applicable to: 2018 BRZ with Smart Key
lock to lock in relation to steering rennlistuser3 BRZ First-Gen (2012+) — General Topics 8 07-10-2019 09:48 PM
Sti lug and lock nuts by McGraw question impossible Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 7 09-18-2016 03:17 AM
Wheel lock install question V_86 DIY (Do-It-Yourself) Guides 6 04-09-2015 09:30 PM
Window and door lock switch Illumination question. HapaHaole BRZ First-Gen (2012+) — General Topics 0 03-05-2014 09:14 PM
CG Lock Seat Belt Lock Biggins Interior Parts (Incl. Lighting) 0 02-03-2014 08:41 AM
