Old 10-28-2022, 10:28 AM   #1
Tekkk
Drives: GT86 white
Delay in engine revs...!
Hello people! Help solve the problem
When my car's engine attains up 2500 rpm in first gear, I push harder on the gas pedal, as the result of this, there is a delay in engine revs. The effect is as if ESP has worked...
video of this problem:
and
Tekkk is offline   Reply With Quote
Old 10-28-2022, 11:14 AM   #2
Is it stock? Any mods?
Old 10-28-2022, 11:26 AM   #3
tomm.brz
Drives: brz 2017 hksv2
start with the very basic
Clean maf and map sensor, reset ecu unplugging battery and try again
Old 10-28-2022, 01:53 PM   #4
Tekkk
Drives: GT86 white
yes, full stock. No mods
Old 10-28-2022, 02:03 PM   #5
Tekkk
Drives: GT86 white
that's exactly what we did, but to no avail
Old 10-28-2022, 03:32 PM   #6
tomm.brz
the fact that it starts exactly at 2800 where the stock oem tune switches to DI only at relatively low loads, makes me think of problems with the DI itself
Can you try to floor it heavily at 2000 rpm instead of give partial throttle?
like 2000 rpm floor it 100%... if you are quick enough it should still cover the zones where it uses 50/50% of injections at least untill 3200 rpm, so the esitation should begin a bit later
in the case it is the DI, don t really know how to help you, maybe some DI injectors is clogged up or faulty
The Following 2 Users Say Thank You to tomm.brz For This Useful Post:
Ultramaroon (10-28-2022), x808drifter (10-29-2022)
Old 10-30-2022, 06:59 PM   #7
Tekkk
Drives: GT86 white
And so, here is the result!
There is no delay when I increase speed sharply from 2000rpm.
But it's all in 1st gear!
Let me remind you that the delay occurs with a sharp increase in speed at 2500rpm, it is in this range that 2nd gear is switched on
Old 10-30-2022, 07:07 PM   #8
Tekkk
Drives: GT86 white
An interesting moment, using the tiptronic, I switched the speed to 2nd gear at 2000rpm, as a result ... the same delay!
Bottom line, the delay occurs at the moment of gear shifting from 1 to 2
Old 10-30-2022, 07:19 PM   #9
Tekkk
Drives: GT86 white
Maybe an automatic transmission torque converter?
Old 10-31-2022, 09:52 AM   #10
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
Sounds like my last auto car when it got super hot from racing so maybe...
Old 11-01-2022, 11:08 AM   #11
Tekkk
Drives: GT86 white
I made such a test, please look above, there is a video
Old 11-01-2022, 11:21 AM   #12
tomm.brz
dont know what to say sorry, i d a log from Obd to help you more
Old 11-03-2022, 09:35 AM   #13
Tekkk
Drives: GT86 white
Another interesting observation. I arrived at the service, got into the car with a mechanic for a test drive - and there was no delay! worked perfectly! No matter how hard I try. But as soon as the car was turned off and restarted, this problem immediately got out, the delay reappeared. ECM? UNIT-AT CONTROL ?
Old 11-15-2022, 05:45 PM   #14
Tekkk
Drives: GT86 white
heeeelp guys
Delay in engine revs...! Tekkk Issues | Warranty | Recalls / TSB 0 10-28-2022 09:22 AM
Engine knocking around 1.8 revs SammyXNA Engine, Exhaust, Transmission 21 11-08-2021 10:16 AM
Engine over revs randomly w/ no throttle response disruptorbeam Issues | Warranty | Recalls / TSB 14 02-12-2021 01:27 AM
Boost vs Revs: Comparing Internal Engine Stresses Williampreza Engine, Exhaust, Transmission 15 04-10-2018 08:41 PM
2.5L with lower revs/more torque, or 2.0L with higher revs? Superhatch Engine, Exhaust, Transmission 124 08-28-2013 12:20 PM
