View Poll Results: How do you stop your car (Manual Transmission)
Downshift one gear at a from current gear to first gear then to neutral with brake application 8 16.00%
Shift to Neutral and use the brakes to come to a complete stop 17 34.00%
Stay in the same gear until less than 10 mph, apply brakes, then shift to neutral b4 a complete stop 20 40.00%
None of the above (post your method). 5 10.00%
Voters: 50. You may not vote on this poll
Old 08-21-2012, 12:08 AM   #1
pinoyplaya
Drives: WRB MT-BRZ LMTD
How do you stop your car? (Manual Transmission)
So, what are your guys method of stopping your car?
1.) Downshift one gear at a time from current gear to first gear then to neutral with brake application.
2.) Shift to Neutral and use the brakes to come to a complete stop
3.) Stay in the same gear and apply brakes until the car hits nearly 10 mph, then shift to neutral b4 coming to a complete stop to avoid stalling.
4.) None of the above (post your method).
BYE: WRB MT-BRZ LMTD
Drove the car off the lot at 8/6/12 @ 8:06 PM
Traded for Black 2013 Camaro 2SS RS
pinoyplaya is offline   Reply With Quote
Old 08-21-2012, 12:12 AM   #2
cobrabyte
cobrabyte's Avatar
Drives: 2013 BRZ, 2002 WRX
I rev-match/downshift and brake if I see I'm going to be going again before stopping. Otherwise, I save the fuel and just clutch and brake.
cobrabyte is offline   Reply With Quote
Old 08-21-2012, 12:25 AM   #3
Lee358
Lee358's Avatar
Drives: nissan frontier, DGM MT BRZ
i do this as well heel toe downshift gotta revmatch but i mostly use brakes
Lee358 is offline   Reply With Quote
Old 08-21-2012, 02:43 AM   #4
Jeffboyarrdee
Jeffboyarrdee's Avatar
Drives: 2013 Subaru brz limited wr blue
When I want to stop I usually just go to neutral and brake. I feel like in the long run its easier and cheaper to replace brakes than to wear out your transmission faster and yes also the gas...
Jeffboyarrdee is offline   Reply With Quote
Old 08-21-2012, 08:28 AM   #5
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
you don't save fuel when you clutch in, cuz now you're in neutral.
if you're coming to a complete stop, you brake in whatever gear you're in until the rpms drop below 1500, then you clutch in.
Old 08-21-2012, 09:47 AM   #6
5hairpins
5hairpins's Avatar
Drives: 2013 MT Asphalt FR-S
Any and all of the options above. If I am coming up on a light or a turn and there is no traffic, I downshift through the gears. If there are cars at the light, I will go to neutral and coast. It all depends on whether or not there is opportunity to get back up to speed quickly.
5hairpins is offline   Reply With Quote
Old 08-21-2012, 10:52 AM   #7
whaap
whaap's Avatar
Usually I'll down shift a gear at a time till I'm in second gear and after I'm stopped I'll put it in first gear. Whether or not I rev match depends on the type of driving I'm doing at the time. If I'm pushing the edge a little I'll rev match. If I'm just out smelling the roses I probably won't.
whaap is offline   Reply With Quote
Old 08-21-2012, 11:26 AM   #8
Superhatch
AIM4APX
Superhatch's Avatar
Drives: 2013 WRB BRZ Limited
For DD I use the brakes while shifting to neutral.
While on track I use brakes + engine braking sometimes but ideally I use brakes + rev match.
"It's very difficult to present technology as an overtly positive sales device to people who want an emotional car" -Chris Harris
Superhatch is offline   Reply With Quote
Old 08-21-2012, 12:24 PM   #9
S2kphile
Resident HoneyBadger
S2kphile's Avatar
Drives: Toyota Tacoma TRD Off-Road
I just use the brake and put the car in neutral if I know there is gonna be a complete stop. If not, then I brake and then put it into 2nd gear then gas it if I need to accelerate. Simple as f**k for DD.
Walk like a King, Be like a Sir, Swag it out like a Boss
S2kphile is offline   Reply With Quote
Old 08-21-2012, 12:40 PM   #10
track_warrior
Track Junkie
track_warrior's Avatar
Drives: Faster than the Stig!
Rev Match while braking and once i get to second gear i shift to neural and coast at a slower speed. I only do this to practice heel & toeing as much as i can.
Compensating a heavy car with horsepower is like giving an alcoholic cocaine to sober him up...
track_warrior is offline   Reply With Quote
Old 08-21-2012, 02:40 PM   #11
bestwheelbase
Drives: 1985 P-Type
Same as @pcasso87 -- heel and toe down to 2nd gear.
Old 08-21-2012, 02:54 PM   #12
Kimsey47
Kimsey47's Avatar
Drives: 2016 STI DGM
Agreed with this method!
Subaru STI :
Old 08-21-2012, 03:05 PM   #13
Stu baru
Official Cobb beer knurd
Stu baru's Avatar
Drives: 2013 BRZ-L MT SWP
Usually a combination of downshifting and braking with clutch in.
Don't text while driving, everyone around you will appreciate you not endangering their lives.
Stu baru is offline   Reply With Quote
Old 08-23-2012, 07:03 AM   #14
dori.
Señor Member
dori.'s Avatar
Drives: white BRZ 6MT
I stay in gear until a low speed and shift to neutral when I come to a full stop. I stay in gear for safety reasons, because the added engine braking will help you in the case of an emergency.
Otherwise, if I have to just slow down to get around a corner, I rev match and heel toe as necessary down to the gear that'll pull me through the turn.
dori. is offline   Reply With Quote
New Manual transmission drivers Q&A garsh0p Engine, Exhaust, Transmission 136 10-30-2014 07:14 PM
Second Impression with a Manual Transmission Bristecom Scion FR-S / Toyota 86 GT86 General Forum 22 08-30-2012 08:21 PM
FT-86, manual or automatic transmission??? luisjr Scion FR-S / Toyota 86 GT86 General Forum 22 07-25-2012 03:00 AM
topspeed difference between manual transmission and automatic transmission torquemada BRZ First-Gen (2012+) — General Topics 51 05-04-2012 07:54 PM
Another reason to buy a manual transmission car... xantonin Off-Topic Lounge [WARNING: NO POLITICS] 4 08-10-2011 11:30 AM
