| Off-Topic Lounge [WARNING: NO POLITICS] For all off-topic discussion topics. |
| View Poll Results: How do you stop your car (Manual Transmission) | |||
| Downshift one gear at a from current gear to first gear then to neutral with brake application |
8 | 16.00% |
| Shift to Neutral and use the brakes to come to a complete stop |
17 | 34.00% |
| Stay in the same gear until less than 10 mph, apply brakes, then shift to neutral b4 a complete stop |
20 | 40.00% |
| None of the above (post your method). |
5 | 10.00% |
| Voters: 50. You may not vote on this poll | |||
Drives: WRB MT-BRZ LMTD
How do you stop your car? (Manual Transmission)
So, what are your guys method of stopping your car?
1.) Downshift one gear at a time from current gear to first gear then to neutral with brake application. 2.) Shift to Neutral and use the brakes to come to a complete stop 3.) Stay in the same gear and apply brakes until the car hits nearly 10 mph, then shift to neutral b4 coming to a complete stop to avoid stalling. 4.) None of the above (post your method).
BYE: WRB MT-BRZ LMTD
Drove the car off the lot at 8/6/12 @ 8:06 PM Traded for Black 2013 Camaro 2SS RS |
#2 |
Drives: 2013 BRZ, 2002 WRX
I rev-match/downshift and brake if I see I'm going to be going again before stopping. Otherwise, I save the fuel and just clutch and brake.
#3 |
Drives: nissan frontier, DGM MT BRZ
#4 |
Drives: 2013 Subaru brz limited wr blue
When I want to stop I usually just go to neutral and brake. I feel like in the long run its easier and cheaper to replace brakes than to wear out your transmission faster and yes also the gas...
#5 | |
i'm sorry, what?
Drives: Canada
if you're coming to a complete stop, you brake in whatever gear you're in until the rpms drop below 1500, then you clutch in.
#6 |
Drives: 2013 MT Asphalt FR-S
Any and all of the options above. If I am coming up on a light or a turn and there is no traffic, I downshift through the gears. If there are cars at the light, I will go to neutral and coast. It all depends on whether or not there is opportunity to get back up to speed quickly.
#7 |
Drives: '13 FR-S firestorm, 6 mt - '11 CR-V
Usually I'll down shift a gear at a time till I'm in second gear and after I'm stopped I'll put it in first gear. Whether or not I rev match depends on the type of driving I'm doing at the time. If I'm pushing the edge a little I'll rev match. If I'm just out smelling the roses I probably won't.
#8 |
AIM4APX
Drives: 2013 WRB BRZ Limited
For DD I use the brakes while shifting to neutral.
While on track I use brakes + engine braking sometimes but ideally I use brakes + rev match.
"It's very difficult to present technology as an overtly positive sales device to people who want an emotional car" -Chris Harris
#9 |
Resident HoneyBadger
Drives: Toyota Tacoma TRD Off-Road
I just use the brake and put the car in neutral if I know there is gonna be a complete stop. If not, then I brake and then put it into 2nd gear then gas it if I need to accelerate. Simple as f**k for DD.
![]() Walk like a King, Be like a Sir, Swag it out like a Boss |
#10 |
Track Junkie
Drives: Faster than the Stig!
Rev Match while braking and once i get to second gear i shift to neural and coast at a slower speed. I only do this to practice heel & toeing as much as i can.
Compensating a heavy car with horsepower is like giving an alcoholic cocaine to sober him up...
#12 | |
Drives: 2016 STI DGM
Subaru STI :![]() |
#13 |
Official Cobb beer knurd
Drives: 2013 BRZ-L MT SWP
Usually a combination of downshifting and braking with clutch in.
Don't text while driving, everyone around you will appreciate you not endangering their lives.
#14 |
Señor Member
Drives: white BRZ 6MT
I stay in gear until a low speed and shift to neutral when I come to a full stop. I stay in gear for safety reasons, because the added engine braking will help you in the case of an emergency.
Otherwise, if I have to just slow down to get around a corner, I rev match and heel toe as necessary down to the gear that'll pull me through the turn.
| New Manual transmission drivers Q&A | garsh0p | Engine, Exhaust, Transmission | 136 | 10-30-2014 07:14 PM |
| Second Impression with a Manual Transmission | Bristecom | Scion FR-S / Toyota 86 GT86 General Forum | 22 | 08-30-2012 08:21 PM |
| FT-86, manual or automatic transmission??? | luisjr | Scion FR-S / Toyota 86 GT86 General Forum | 22 | 07-25-2012 03:00 AM |
| topspeed difference between manual transmission and automatic transmission | torquemada | BRZ First-Gen (2012+) — General Topics | 51 | 05-04-2012 07:54 PM |
| Another reason to buy a manual transmission car... | xantonin | Off-Topic Lounge [WARNING: NO POLITICS] | 4 | 08-10-2011 11:30 AM |
