Drives: Black Scion FR-S
Help pls traction control light comes on and check engine too
So my car has 106,000 miles, I changed the spark plugs and ignition coils 1,000 miles ago and haven’t gotten any problems till now. The TC light comes on for a few secs then goes away and the CEL comes on, and sometimes goes away on its own or I’ll just erase it since car feels ok.THERE HAS BEEN NO TIME THAT ONLY ONE LIGHT AND THE OTHER DOESNT, they both light up at the same time but the tracción one disappears and that’s when I start experiencing some of this stuff
So this happens during acceleration usually but nothing crazy since I don’t wanna push the car, it has happened at 65mph and as low as 25mph the code that reads is P0353 but I check for misfires and got 0 everything in the car felt good only difference I noticed where -My brakes would grab on harder than usual when I got to 13mph without even pressing on them (only happens when CEL is on, if I erase it brakes work fine) -my brakes are really squeaky even while on acceleration, kinda sounds like they are engaged -little loss of power nothing crazy just i notice it Here’s the interesting part tho -I’ve also had my rpm needle drop a little and then go back up to position at a stop -I have like a gas pedal deadzone where i feel like I have to press down more than I used to -feels slower than usual on 1k-3.5k rpm if I push it passed 3.5 that’s when it starts feeling “fast” -I have an exhaust so I can hear the engine and when coming to a stop it feels like engine goes silent for a bit and that’s when the rpm drops from 500 to 400 then comes up and stays at 500 -today I even noticed my lights dim a little when coming to a stop at the same time the rpm dropped to 400. I can’t really take it to a mechanic since my CEL goes away sometimes fast or sometimes it takes a day but the code it reads me is for my ignition coils, which is weird since they are brand new. Now I’m thinking it’s my brakes since they are really worn out, ima change them this week seee if that solves my problem, I’ve also thought about it being my speed sensors ? I read that turns the TC light on too or lastly my 3d ignition coil but I barely have 1k miles with it so I don’t see why it would fail now. What do y’all think? |
Make sure all you coil packs are secure. Also nothing saying you don't have a bad coil no matter how new it is.
You have a code that is telling you what is up so why blame brakes?
#3 | |
I’m only blaming the brakes because I’ve never had the TC light come on at the same time which makes me think it is something other than my ignition coils |
#4 | |
| The Following User Says Thank You to Tcoat For This Useful Post: | Limitz (10-12-2022) |
ProCrastinationConsultant
afaik, traction control doesn't engage on motor problems. i suspect you've got more than one issue here.
| The Following 3 Users Say Thank You to soundman98 For This Useful Post: |
#7 | |
Drives: Crapcan
TC light may come on with cel, can't remember. Should still be active unless there is a can com issue with the abs/TC module which not all scanners see.
| The Following User Says Thank You to NoHaveMSG For This Useful Post: | soundman98 (10-13-2022) |
#8 | |
After cutting it and bolting it on tight I tried to turn the car on and it WOULD turn on and it would rev up and then just die right away. I also got a new code P0451, I have no clue why it just turned on when all I touched was the ignition coils. Going to have to call a mechanic unless anyone has any ideas? |
#9 | |
| The Following 2 Users Say Thank You to Tcoat For This Useful Post: | NoHaveMSG (10-13-2022), soundman98 (10-13-2022) |
#10 | |
What do you mean you "cut a bolt"?
| The Following User Says Thank You to Tcoat For This Useful Post: | soundman98 (10-13-2022) |
#11 |
Drives: Crapcan
It's honestly been so long since I've had a cel I don't remember lol I think the last two times was Thunder Hill in 16' for a misfire, and when I blew up an engine at the Ridge in 20'.
| The Following 3 Users Say Thank You to NoHaveMSG For This Useful Post: |
#12 |
I have never even seen a cel much less limo mode!
| The Following 3 Users Say Thank You to Tcoat For This Useful Post: |
#13 |
now i want limo mode!
knock on wood, my vehicles haven't thrown anything more serious than a tire pressure light. and i'd like to keep it that way!
#14 | |||
Señor Member
I am with Tcoat on wanting to know what you cut?
1974 TA22 Celica
2013 86 GT |
| Check Engine light and Traction Control Light | JeRM | Issues | Warranty | Recalls / TSB | 25 | 06-02-2023 10:00 PM |
| Check engine light then a traction control light then just a check engine... and then | Jstyle | Issues | Warranty | Recalls / TSB | 13 | 02-15-2021 06:10 PM |
| Check engine and traction control symbol in rental | Veejayy | Scion FR-S / Toyota 86 GT86 General Forum | 10 | 07-11-2017 11:00 PM |
| Engine Check light, Traction Control light, cruise control light all on suddenly | wqc3241 | Software Tuning | 2 | 01-10-2016 08:37 AM |
| First Check Engine Light and Traction control | QFry | Issues | Warranty | Recalls / TSB | 26 | 10-05-2014 12:27 AM |
