Old 10-09-2022, 02:20 PM   #1
congee
congee's Avatar
Drives: SSM BRZ
Oil Fill Cap Broke
Hello,
While changing my oil today on my 2013 brz. The stock oem plastic oil fill cap snapped and a piece the size of a finger nail broke into the fill hole. Any suggestions and anyone know how bad this will effect the engine??
Thanks
congee is offline   Reply With Quote
Old 10-09-2022, 03:33 PM   #2
Ultramaroon
not playing cards
Ultramaroon's Avatar
Tough call. Would be captured by the pickup screen but might hang up in the pickup tube itself. If it doesn't come out draining the oil, drop the pan and remove it to be safe.
The Following 4 Users Say Thank You to Ultramaroon For This Useful Post:
alphasaur (10-10-2022), Capt Spaulding (10-09-2022), congee (10-10-2022), x808drifter (10-09-2022)
Old 10-09-2022, 04:19 PM   #3
soundman98
ProCrastinationConsultant
soundman98's Avatar
but then the fill opening is above one of the cam shafts. do the cams drain directly into the lower pan?
Old 10-09-2022, 07:31 PM   #4
Ultramaroon
not playing cards
They do. That's the main reason for all the shit in the screens from the j02 recall. I could see it being chewed up on the way down, but
soundman98 (10-10-2022)
Old 10-10-2022, 01:38 AM   #5
soundman98
soundman98's Avatar
i'm really more curious how a hand-tightened plastic cap on a machined aluminum surface cracked enough to fall apart...
Old 10-10-2022, 02:44 AM   #6
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
I'm betting it was over tightened and they used vice grips or something to get a hold on it
JDL EL Recirc manifold, Boostlab BL58x Turbo w/ T51R, 17x9 ARC-8, IAG block
The Following 2 Users Say Thank You to DarkPira7e For This Useful Post:
soundman98 (10-10-2022), x808drifter (10-11-2022)
Old 10-10-2022, 06:05 AM   #7
22R
22R
22R's Avatar
Drives: 2012 Camry SE 2017 Toyota 86
Lawd !!
22R
22R is offline   Reply With Quote
The Following 2 Users Say Thank You to 22R For This Useful Post:
DarkPira7e (10-10-2022), x808drifter (10-11-2022)
Old 10-10-2022, 10:44 AM   #8
Breadman
Breadman's Avatar
Drives: 2017 BRZ w/PP
Probably crossthreaded it and magilla gorillaed it in
Breadman is offline   Reply With Quote
Old 10-10-2022, 11:26 AM   #9
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
Very strange. Impossible to cross thread. It's like a Playskool motor skill, eye-hand coordination toy. Need the full story.
DarkPira7e (10-10-2022), soundman98 (10-11-2022)
Old 10-10-2022, 05:40 PM   #10
congee
congee's Avatar
Drives: SSM BRZ
The cap was too tight so I used pliers to clamp the insides of the handle(where theres a U shaped space on each end)and after getting it off. Rested it on the opening and didn’t know one end was cracked so once i lifted it up, the piece fell right in…. Rookie mistake.
Sadly, drained the oil and nothing came out but ive driven it for around 100kms and no issues so far. Will probably change the oil again in a few days just to be safe until my mechanic is free to pull the oil pan. He did say there shouldn’t be too big of a problem bit better safe than sorry
The Following 5 Users Say Thank You to congee For This Useful Post:
Sapphireho (10-11-2022), soundman98 (10-11-2022), Tcoat (10-10-2022), Ultramaroon (10-10-2022), x808drifter (10-11-2022)
Old 10-10-2022, 06:29 PM   #11
Ultramaroon
not playing cards
Consider the size of the drain. When you say "fingernail," I wonder if the fragment is too big to come out the drain. Either that, or it's just laying in the bottom of the pan, minding its own business.
congee (10-10-2022), x808drifter (10-11-2022)
Old 10-10-2022, 07:46 PM   #12
congee
congee's Avatar
Drives: SSM BRZ
Hoping its just sitting at the bottom of the pan or lodge into something but it should fit through the drain hole. i suspect it’s probably somewhere in the oil fill area since theres a bunch of random gears/mechanical parts near the opening. Probably trapped inbetween something. My biggest fear is that it breaks down into smaller pieces or melts and then somehow gets through the pick up screen and filter. Going to put in new oil again and then again in a month or so just to be safe.
Old 10-11-2022, 12:01 AM   #13
Ultramaroon
not playing cards
Meh.... Don't waste good oil.
Old 10-11-2022, 08:02 AM   #14
Sapphireho
Famous Potatoes
Sapphireho's Avatar
So to clarify size, it is this piece?
Rocker arm broke and broke my valve cover... j0hnnykthx Issues | Warranty | Recalls / TSB 9 08-07-2020 09:12 AM
Over fill oil Halo_2 Issues | Warranty | Recalls / TSB 14 07-18-2020 10:18 AM
Is it necessary to pre-fill the oil filter? lupindub Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 27 06-07-2016 04:58 PM
Fill and paint? or PDR... rhythmM Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 3 02-12-2014 10:36 PM
First fill-up... mit_peid Scion FR-S / Toyota 86 GT86 General Forum 3 01-20-2013 06:46 PM
