Old 09-29-2022, 03:31 PM   #1
Swolzee
Swolzee's Avatar
Drives: Honda Insight
The Grapes of Rasp
BREAKING NEWS, this just in. A catless exhaust is loud AF!
My setup:
- JDL 4-2-1 EL,
- 2.5" stainless OP
- 2.5-3" stainless FP
- Perrin 3" resonated CB
I'm not sure what my expectations were initially but this wasn't it. The db's are a real thing but the raspyness of it is unreal. I have had many loud exhausts from many types of 4cyl and that's certainly a factor but the rasp is next level.
I could live with the db's being what they are especially once I get my rear seat delete barrier installed with acoustical foam glued to the back and I drop a bag of rockwool safeNsound in the spare tire and rear seat cavities.
To directly combat the issue I first plan to install the 5 STI exhaust cushions (there is a tremendous amount of vibration resonance), and weld in a 3" vibrant ultra quiet resonator into the FP.
Are there any other recommendations to help eliminate the rasp?
Swolzee is offline   Reply With Quote
Old 09-29-2022, 03:40 PM   #2
spcmafia
spcmafia's Avatar
Drives: 2018 Subaru BRZ
My setup:
- JDL 4-2-1 EL,
- 2.5" stainless OP
Catless FP are a contributor to rasp on a setup, due to proximity to headers. A double resonated one like HKS would be ideal. Or even a HFC. The JDM hangers will help with vibrations/drone. But other than that it would come down to Catback choice.
The Following 9 Users Say Thank You to spcmafia For This Useful Post:
DarkPira7e (09-29-2022), flippy (09-30-2022), Jdmjunkie (09-29-2022), Spuds (10-05-2022), Swolzee (09-29-2022), Tcoat (09-30-2022), weederr33 (09-29-2022), whataboutbob (09-29-2022), x808drifter (09-30-2022)
Old 09-29-2022, 11:04 PM   #3
Swolzee
Swolzee's Avatar
This is correct.
So who wants to buy a catless front pipe lol.
I went ahead and swapped back in the the stock front pipe and it resolved about 75% of the rasp and actually improved the sound to a deeper burble not as sharp and tinny. Free flow and HP be damned, it was intolerable.
Thanks!
The Following 6 Users Say Thank You to Swolzee For This Useful Post:
JBezugs (10-05-2022), spcmafia (09-30-2022), Spuds (10-05-2022), Tatsu333 (10-22-2022), Tcoat (09-30-2022), whataboutbob (09-29-2022)
Old 09-30-2022, 11:23 AM   #4
wbradley
Sarcastic SOB
wbradley's Avatar
I thought this was a.discussion of Steinbeck's work.
The Following 2 Users Say Thank You to wbradley For This Useful Post:
cmiovino (09-30-2022), WildCard600 (10-15-2022)
Old 09-30-2022, 11:45 AM   #5
cmiovino
cmiovino's Avatar
Drives: 2017 BRZ PP, 2004 WRX
I was just popping in to say the OEM front pipe is really good at keeping rasp at bay, especially with catless headers people often go to. Remember that swapping to aftermarket front pipes tend to only net a few minor whp and it's generally not worth the money and added headache (literally).
If you're running a catless header, stock front pipe, and still have volume/rasp issues, it's likely the catback you're running at that point.
cmiovino is offline   Reply With Quote
Old 10-05-2022, 12:48 PM   #6
JBezugs
Good Job Subaru!
JBezugs's Avatar
Drives: '24 CX-50 Meridian
I have the JDL 4-2-1 header as well but with no real rasp to speak of. Like others have stated, that's because of using the OEM front pipe with the OEM cat. My catback is a bit drony at highway speeds when under load (going up hills) between like 120-135kph, but the JDM "exhaust cushions" (Hangers) cured maybe 50-60% of the drone. I'm still looking to add a vibrant resonator to it to help curb the remaining drone, or just swapping the catback out all together and going back to stock there, as I drive all highway these days.
With the swap you've done on the front pipe, that's a huge help! But with JDM STI hangers, you should see a significant cut down of drone on your setup as well.
My setup:
- JDL 4-2-1 Header
- Stock OP
- Stock FP
- Invidia R400
JBezugs is offline   Reply With Quote
Old 10-05-2022, 01:20 PM   #7
Racecomp Engineering
Originally Posted by JBezugs View Post
I have the JDL 4-2-1 header as well but with no real rasp to speak of. Like others have stated, that's because of using the OEM front pipe with the OEM cat. My catback is a bit drony at highway speeds when under load (going up hills) between like 120-135kph, but the JDM "exhaust cushions" (Hangers) cured maybe 50-60% of the drone. I'm still looking to add a vibrant resonator to it to help curb the remaining drone, or just swapping the catback out all together, as I drive all highway these days.
My setup:
- JDL 4-2-1 Header
- Stock OP
- Stock FP
- Invidia R400
Do you run all 5 JDM hangers?
Is the Rage Against the Machine version of "The Ghost of Tom Joad" better than the Bruce Springsteen original?
- Andrew
Old 10-05-2022, 02:18 PM   #8
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
You'll want a cat to help with rasp.
I took some back to back when I had a HKS dual resonated installed vs a 2.5" high flow catted and resonated FP, both with OEM catbacks. Catted setup removed the rasp.
The rasp with the UEL headers was only low RPM and heavy load. Obviously different headers, I don't imagine you'll get rid of all rasp with just resonators.
Sidenote, got any exhaust clips? My JDL is showing up any week now and I'm always looking for options.
Old 10-05-2022, 02:27 PM   #9
JBezugs
Good Job Subaru!
JBezugs's Avatar
- Andrew
Yes to both inquiries!
This is what the setup currently sounds like for reference. Mic is placed on the rear bumper.
The Following 2 Users Say Thank You to JBezugs For This Useful Post:
Racecomp Engineering (10-05-2022), RToyo86 (10-06-2022)
Old 10-05-2022, 06:39 PM   #10
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
like this?
RToyo86 (10-06-2022), x808drifter (10-06-2022)
Old 10-06-2022, 05:48 PM   #11
kevaughan
kevaughan's Avatar
Drives: BMW E30, 2014 FR-S
I did the STI hangers (two the rear) and a Vibrant Resonator. Drone was significantly reduced. OEM front pipe helped the most of course.
kevaughan is offline   Reply With Quote
Old 10-06-2022, 08:58 PM   #12
JBezugs
Good Job Subaru!
JBezugs's Avatar
Which Vibrant resonator did you end up getting installed? Did you install it onto the front pipe, or on the catback portion?
Old 10-07-2022, 10:22 PM   #13
Grady
Grady's Avatar
Best way to eliminate rasp is to install a turbo!!!!!
The Following User Says Thank You to Grady For This Useful Post:
x808drifter (10-09-2022)
Old 10-15-2022, 03:37 PM   #14
Lantanafrs2
Drives: 2013 frs red
After the header, stock is best
The Following User Says Thank You to Lantanafrs2 For This Useful Post:
x808drifter (10-16-2022)
Will header cause rasp? Tysoncrosby21 Engine, Exhaust, Transmission 8 02-12-2017 05:09 AM
headers rasp mamamiaellis Engine, Exhaust, Transmission 13 05-20-2015 11:20 PM
Rasp issue, need help on fix? slyder Engine, Exhaust, Transmission 9 01-23-2015 06:09 PM
Glasspack to get rid of rasp? dem00n Other Vehicles & General Automotive Discussions 3 10-18-2014 10:56 AM
Rasp help??? Gshoxx Engine, Exhaust, Transmission 3 05-01-2014 02:20 AM
