Old 09-28-2022, 10:37 AM   #1
funkjaw
Drives: 16' WWB
Dual purpose street/rally cross coilovers
Looking for coil overs that I can raise above OE height for rally cross, set at OE height for daily driving, and go lower than OE height for everything else like drift events and such. Tall order? Probably.... But I happened to stumble upon these which might fit that bill:
https://www.gorillaoffroadcompany.co...32161694220350
Anyone have any experience these Gorilla Silverback coilovers? Any suggestion for other coilovers that might accomplish my goals?
Car is K24 swapped using the Kpower kit
Thanks----
funkjaw is offline   Reply With Quote
Old 09-28-2022, 11:56 AM   #2
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Have you considered removable spacers? I can't comment on efficacy or reliability, but it's fast and simple
JDL EL Recirc manifold, Boostlab BL58x Turbo w/ T51R, 17x9 ARC-8, IAG block
Old 09-28-2022, 12:24 PM   #3
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
I'm a suspension noob. Does changing ride height change toe and camber too?
Old 09-28-2022, 01:49 PM   #4
cmiovino
cmiovino's Avatar
Drives: 2017 BRZ PP, 2004 WRX
Yes. Typically if you lower the car, camber "negatively increase". AKA, you might go from -2.0 to -2.5.
Then anytime camber changes, toe changes. Adding camber bolts for example, usually toes you out. I remember when I added camber bolts for an additional degree of camber, it toed the front out 1/8".
cmiovino is offline   Reply With Quote
Old 09-28-2022, 01:52 PM   #5
marco_mc22
Drives: Toyota 86
Reiger 3 ways… the best.
marco_mc22 is offline   Reply With Quote
Old 09-29-2022, 06:16 PM   #6
funkjaw
Drives: 16' WWB
This might be a great idea actually!
Yup I did some digging and apparently Reiger will basically make me anything I want if I give them my end goals... issue is it will be expensive as all hell haha almost as much as the car is worth. So I'll likely figure out a cheaper route.
Old 09-29-2022, 07:23 PM   #7
strat61caster
strat61caster's Avatar
Leave oem height, no aftermarket setup is as soft as oem springs to handle the big bumps, put Bilstein B6 on for better ride control and durability, add desired amount of camber, send it until something breaks. Tune bumpstops for like $100 if necessary.
Adjusting ride heights and alignment multiple times per year is a pain in the ass, you’re going to waste 1-2 hours of your life changing setup for each event? Gross. If you want a “do it all setup” you’re likely not trying to win anything so KISS - keep it simple stupid. For me time driving > time wrenching.
Edit: dirtfish uses a reiger front strut and a bilstein Motorsport rear damper, looks like about a $5k setup.
https://dirtfish.com/archive/the-imp...pension-setup/
ineedyourdiddly
Old 10-01-2022, 03:06 AM   #8
grumpysnapper
grumpysnapper's Avatar
I did the same thing with a hand made set of WRC Ohlins made from scratch for my car, in Holland...and I can confirm its mega expensive (and that was after I think he eased the costs for me because he enjoyed the project so much), and takes months of logistics and manufacture.
Ultimately it was worth it for me, they are genuinely mind blowing astonishing, but it is overkill for a road car pretending to be a rally car (you simply can't get the length of travel you really need).
I run it at normal road height with 16" wheels and the ride is absolutely gorgeous...well sorted rally suspension is totally magic on less than perfect surfaces.
grumpysnapper is offline   Reply With Quote
Old 10-18-2022, 01:55 PM   #9
funkjaw
Drives: 16' WWB
UPDATE
I contacted Flatoutsuspension via Facebook and told them about my weird desire for my car to be DD, Track, Drift, and Rally-X ready. They suggested they make me a custom version of their "Lite" coilovers so it gives me +- 1" adjustability from OEM height. Also told them that I had K24 swapped the car so they will make a small tweak to spring rates.
https://flatoutsuspension.net/products/brz-grl
Ordered them, total cost was $1600
Will update this thread once I get em in.
Old 10-18-2022, 04:44 PM   #10
imnotsureaboutbrz
Drives: between cars...
good luck, I'm curious.
imnotsureaboutbrz is offline   Reply With Quote
Old 10-18-2022, 05:05 PM   #11
Pat
Pat's Avatar
Drives: 2023 BRZ
You have competing goals. If it does A very well, it won't do B or C very well. Spending more money means you'll have less compromise. But at any amount you spend, you'll still be making sacrifices in the areas for which it is not optimized.
If you're willing to make that compromise....well, that's your choice. That's also what I have chosen. But I went into it eyes wide open. And my range goes from a performance street setup to time trials on 200 TW tires. Your range is much bigger, which means more compromise.
Old 10-19-2022, 12:16 AM   #12
funkjaw
Drives: 16' WWB
I do agree! In my case I don't have any aspirations to be competitive, just wanna have fun without destroying the car on the dirt (hence the lift) so this works out. Should be a lot of fun in the end!
Old 01-20-2023, 07:21 PM   #13
funkjaw
Drives: 16' WWB
Update
I ended up getting Flatout GR-Lite coilovers and started a review thread here:
https://www.ft86club.com/forums/showthread.php?t=152318
Old 01-21-2023, 04:29 PM   #14
Spawn_Of_Creation
Human
Drives: 2015 BRZ Black
When you lift, you need rear subframe spacers to adjust where the rear wheels sit in the wheel well. Having only coilovers to lift will mess with handling due to the angles.
"Always listen to experts. They'll tell you what can't be done, and why. Then do it." - The Notebooks of Lazarus Long
Spawn_Of_Creation is offline   Reply With Quote
Ricky's Neptune Blue GR86 6MT Dual-Purpose Track Car/Commuter Redemption Build Wrecky_Flowers_ Member's Car Journals 15 11-30-2022 02:15 PM
Ricky's Dual-Purpose Track Car/Commuter Build Wrecky_Flowers_ Member's Car Journals 16 08-27-2022 11:45 AM
Megan Racing Coilovers - Street / Track / EZ STREET - Starting at $699 Shipped GuerillaRacing Brakes, Suspension, Chassis 149 05-12-2015 05:53 PM
Street/Rally Build z3ro Member's Car Journals 3 06-07-2014 06:21 AM
Cusco Street Zero-A & Street Spec A Coilovers - In Stock And Ready To Ship Enjuku Racing Brakes, Suspension, Chassis 0 09-12-2012 05:12 PM
