| GR86 General Topics (2nd Gen 2022+ Toyota 86) General topics for the GR86 second-gen 86 |
Drives: 2014 Scion FRS
Perfect wheel fitment?
Tossed on some 18x9.5 +45 wheels with 255/35 tires for a meaty and aggressive setup on the GR86! What wheel setups are you guys running?
LMGTFY
Drives: 13 FRS, 91 Miata
17x7s 215
Drives: GR86
I looked around the forum and came across a stickied thread in the wheels section that alleged to answer my question but seemed to have a bunch of broken links on it (at least one of which goes to one of those "would you like to download a virus pretending to be security software" sites).
My question is simply what's the "ideal setup" running stock suspension - where "ideal" means widest wheel/tire combo that doesn't rub, doesn't require modification to the car, and retains stock circumference so the speedometer stays accurate. I know the stock wheels are 18x7.5 +48 and I would like to keep an eye out for a good deal on something lighter but I want to know where the line is between "fits stock" and "needs work". I don't want to roll/shave fenders at all, but coilovers are something I'm considering down the road, maybe. Wheels/tires are an easy sell to the wife because we need a set for winter and I'm thinking the stock wheels will do nicely for that (so I'm not paying someone twice a year to mount/unmount my tires). So what I'm looking for is something along the lines of "18x8 +45 is the biggest that fits without rubbing on a stock car" or whatever the actual numbers would be. After that it's fairly simple to calculate the rubber that goes on that wheel without bulging or throwing off the speedo. |
#4 | |
Drives: 2022' GR86 Premium 6MT
Fitment Industries Gallery is a fantastic tool for figuring out what works and what doesn't work and how it will look. This is a 18x8.5 on a 235/40 stock and it fits perfectly fine and look half decent.
https://www.fitmentindustries.com/wh...i-raijin-stock Quote:
22' Toyota GR86 - Trueno Blue - M/T (CURRENT)
18' Toyota 86 GT Black - Moonslate Gray - M/T (SOLD) 13' Scion FRS - Ultramarine - A/T (SOLD) |
#5 | |
Drives: GR86
Drives: 2022 BRZ
I just picked up my BRZ and put on 18x8.5 plus 43 Wedssport TC105X with 245 40 18 Falken 615k+ tyres. Currently stock suspension till the coilovers go on, it only just clears everything, if you drive like you stole it, minimal scraping when hitting bumps when loaded up in corners. If you drive quickish then zero issues.
#7 | |
Drives: 22 BRZ limited
Drives: 2022 BRZ
I believe on front and rear outer edges, although front could be front springs as there is very little space. Its only minor and I haven't seen any damage on tyres yet.
| Scion FR-S perfect fitment | FRS Megan | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 9 | 04-09-2020 09:18 PM |
| Perfect Fitment ARK Design R5 Wheel for FRS / BRZ | ModinJapan | Groupbuys | 144 | 10-18-2017 04:46 PM |
| f/s 25mm & 20mm spacers- perfect fitment for stock wheels! | DarkCard | Wheels and Tires | 20 | 04-22-2015 05:00 PM |
| TE37 reps. 18x9.5 +34 perfect fitment! 265/35/18 beefy tires! CHEAP!! | dOMEmE | Wheels and Tires | 18 | 05-12-2014 02:16 PM |
| REAL te37's 17x7.5 5x100 et48 with tires; perfect fitment | kwall13 | Wheels and Tires | 10 | 01-16-2014 03:30 AM |
