Old 03-30-2020, 12:16 PM   #1
FRS Megan
FRS Megan's Avatar
Drives: 2015 Scion FR-S
Scion FR-S perfect fitment
So I have stock suspension on my 2015 FRS.
Im looking at Konig Oversteer wheels with either:
18x8 +45mm offset
18x9 +42mm offset
Now for tires I was wondering if I can run 245/40 all around with no rubbing or modifications on the stock suspension?
How about 245/45 all around on the stock suspension ? (perferred)
Help !!!
FRS Megan is offline   Reply With Quote
Old 03-30-2020, 12:30 PM   #2
Vital
Drives: 2015 BRZ
18x8 +45mm offset
18x9 +42mm offset
Help !!!
You will be able to run both of those sizes on stock suspension with a 245/40/18 tire. I would recommend you use a 245/35/18 tire as your other tire choices are tall and that will effect gearing and speedometer.
Vital is offline   Reply With Quote
The Following 2 Users Say Thank You to Vital For This Useful Post:
Spuds (03-31-2020), Tcoat (03-30-2020)
Old 03-30-2020, 02:07 PM   #3
FRS Megan
FRS Megan's Avatar
Okay so im going to go with the 245/40 tire all around.
The 18x9 +42mm offset wouldnt poke out correct ?
Or should i go with the 18x8 +45mm offset ?
I want my wheel flush or a barely poking out
Old 03-30-2020, 02:33 PM   #4
Vital
Drives: 2015 BRZ
No, 18x9 +42 will poke out a little unless you decide to lower your car. If you do not plan on lowering the car than i would go 18x8 +45.
Heres a thread on how it will look. Not the same wheel, but the same specs.
http://www.ft86club.com/forums/showthread.php?t=39679
The Following User Says Thank You to Vital For This Useful Post:
Spuds (03-31-2020)
Old 03-30-2020, 05:50 PM   #5
Leonardo
Country Boy 4 Life
Leonardo's Avatar
18x8 +45mm offset
18x9 +42mm offset
Help !!!
I have 18x9 +42 konig Oversteer wheels with 245/35/18. I added a 12mm spacer in the front and a 15mm in the back to make them flush.
I also have 18x8 konig Oversteer wheels. They need 1" spacers to be flush. Do not stagger, it makes the car handle less than compared to square.
This info is for a car that's lowered 1" and has natural rear camber. You'll want a set of camber bolts for the front. Lowering doesn't add a useable amount of camber to the front.
I LIKE TIRES!
The Following 4 Users Say Thank You to Leonardo For This Useful Post:
Carsnguitars (03-30-2020), mrg666 (03-31-2020), Spuds (03-31-2020), Vital (03-31-2020)
Old 03-30-2020, 08:14 PM   #6
FRS Megan
FRS Megan's Avatar
do you think i could do 255/35 tires all around ?
Old 03-30-2020, 09:54 PM   #7
Carsnguitars
Drives: 2014 FR-S
[QUOTE=Leonardo;3314776]I have 18x9 +42 konig Oversteer wheels with 245/35/18. I added a 12mm spacer in the front and a 15mm in the back to make them flush.
I think your car sits perfect. I'm on 18x8 +40 offset, 225/40/18 MP4S. Square setup. I'm happy with the front, but being lowered on TRD springs, they add a bit of camber in the back, I would like just a little more to flush. This is also with 5mm washer type adapters. I don't want to go to stud type adapters. Just keeping it simple. Will try to get a pic tomorrow, weather permitting...
Briefly off topic. I really like your side skirts! What are they?
Carsnguitars is offline   Reply With Quote
The Following User Says Thank You to Carsnguitars For This Useful Post:
Leonardo (03-31-2020)
Old 03-31-2020, 02:30 AM   #8
Leonardo
Country Boy 4 Life
Leonardo's Avatar
No.
With coils, yes. But I would not suggest it. 255's are for 9.5" wide wheels.
I LIKE TIRES!
Old 03-31-2020, 04:06 AM   #9
FRS Megan
FRS Megan's Avatar
No.
Now I’m looking at:
245/40 set up all around
Eibach lowering springs (1in)
now which rim size (18x8 +45mm or 18x9 +42mm) will not give me a stretch look ?
I want the rim and tire to be flush themselves as well. I do not like the rim sticking out of the tire at all.
Would this setup work and not rub or need modifications ?
Old 04-09-2020, 09:18 PM   #10
sato
sato's Avatar
Drives: Dodge Patitas
Have you played with this tool? Hover mouse over Spring Rate box and you'll see tire/wheel/suspension go up and down for comparison:
https://www.ft86motorsports.com/wheelitfit/
Perfect Fitment ARK Design R5 Wheel for FRS / BRZ ModinJapan Groupbuys 144 10-18-2017 04:46 PM
f/s 25mm & 20mm spacers- perfect fitment for stock wheels! DarkCard Wheels and Tires 20 04-22-2015 05:00 PM
TE37 reps. 18x9.5 +34 perfect fitment! 265/35/18 beefy tires! CHEAP!! dOMEmE Wheels and Tires 18 05-12-2014 02:16 PM
REAL te37's 17x7.5 5x100 et48 with tires; perfect fitment kwall13 Wheels and Tires 10 01-16-2014 03:30 AM
3SDM Wheels for Scion FR-S | In stock in FR-S / BRZ fitment GuerillaRacing Wheels and Tires 13 01-23-2013 06:24 PM
