Old 09-21-2022, 11:24 PM   #1
ZCarHuevos
Drives: stock
Unhappy Excessive Crankcase Pressure
Hi,
I purchased a 2013 Scion FR-S about 3 months ago.
When I bought the car - the intake and exhaust were both removed, an injector seal was damaged. I believe this was because they were aftermarket and the previous owner wanted to keep/sell them. The rear main seal was so far crooked it would shoot out so much oil I could hardly move the car to my lift.
The seal appeared to be installed improperly. I replaced it, reinstalled the intake, purchased a new Borla exhaust, and put the car back together.
From the first drive, the rear main seal began to leak again. Thinking I made a mistake, I installed another one ensuring the seal was barely more than flush (per 1mm spec). Again, after disassembling it it appeared to have been pushed out. From the beginning, I was concerned about the crankcase pressure. I triple checked my hose piping against the service manual/videos and photos I could find on here. I replaced and tested the PCV valve. Grounded the DI ECU as the original bracket wasn't present
I'm truly stumped - I'm thinking compression issues. I'll be buying a new compression tester on Monday as mine is quite old, however most cylinders tested around 90. I knew that was low, but I didn't realize in these cars thats about half of the minimum.
When I pulled the trans the final time, the bellhousing and small area around the seal was full of oil. What would cause this much oil to accumulate here? I had never seen so much. This time the seal was only slightly pushed out.
Some background info:
  1. The car doesn't smoke at all, not even on start up
  2. The seals were both OEM from Toyota
  3. The car runs, drives, and sounds perfectly. I drove it about 300-400 miles
  4. I've had an independent shop for years. This is my first time working on a boxer engine, we mostly do Z's/imports. I'm stumped
  5. Smoke tested from the crankcase breather under the AC compresso to the PCV - no blockages
  6. No water in oil, no shavings before/after the first time I refilled it. A head gasket combustion leak test was also done - negative. Car also doesn't overheat
Does anyone have any idea of what would cause excessive crank pressure? I can't think of anything else that would push the rear main out. The crank itself looks fine, no play either. Surely the car wouldnt run as well as it does with only 90 psi compression tested, correct?
I have some pistons/rods/valve springs etc. ready to order for the rebuild as I'm afraid the rings are shot
ZCarHuevos is offline   Reply With Quote
Old 09-22-2022, 02:28 AM   #2
Ultramaroon
not playing cards
Ultramaroon's Avatar
Nothing unique about a boxer. 90 PSI is shit. Will be interesting to hear how it managed to develop such blow-by and still run.
Old 09-29-2022, 12:13 AM   #3
Turdinator
Señor Member
Turdinator's Avatar
Originally Posted by ZCarHuevos View Post
Does anyone have any idea of what would cause excessive crank pressure... only 90 psi compression tested...
I think you answered your own question. Were all four cylinders around 90psi?
I hope you got the car cheap.
1974 TA22 Celica
2013 86 GT
Old 09-29-2022, 09:03 PM   #4
Lantanafrs2
Drives: 2013 frs red
Car was probably boosted at some point
crankcase pressure, piston rings
86 crankcase side air fuel direction? gujianping88@hotmail.com Scion FR-S / Toyota 86 GT86 General Forum 2 11-25-2020 03:28 PM
WTB: Stock Crankcase Pulley SoCalArgento Want-To-Buy Requests 1 04-17-2017 03:02 AM
FS: Radium Crankcase Catch Can blueap2 Engine, Exhaust, Bolt-Ons 5 07-01-2016 01:39 PM
Radium Catch Can Kit (Crankcase Breather) sw20kosh Engine, Exhaust, Bolt-Ons 3 03-10-2016 09:23 PM
help! crankcase pressure and oil drainage lx93 Forced Induction 2 10-13-2015 07:00 AM
