Old 09-21-2022, 07:06 AM   #1
Evolution99
Drives: '15 GT86
Post ECU Definition Request for BRZ Cal ID: ZA1JA02K XML for ECUflash
Kindly I need a xml file for BRZ Cal ID: ZA1JA02K , for ECUflash. since I can't read the files I pulled from my car and gives me "Uknown ROM Image Error" RR is working great. Unfortunately, I tried searching every place, but no good. Please, someone help!
2015 GT86 AT
Evolution99 is offline   Reply With Quote
Old 09-21-2022, 01:38 PM   #2
elBarto
elBarto's Avatar
Drives: Toyota GT86
You can use a ZA1JA01I rom instead.
"Oversteer is when your ass hits the wall, Understeer is when your face hits the wall!" - Unknown Stockcar driver
BeNeLux FB group: GT86/BRZ Owners
elBarto is offline   Reply With Quote
Old 09-22-2022, 02:58 AM   #3
AussieBRZ
AussieBRZ's Avatar
Drives: WRB BRZ
2015 GT86 AT
You can make a fleash definition for any rom
Creating a bare bones definition for flashing a ROM with no existing definition
Useful if your car has old ROM not defined and you want to try update and be able to flash back to old ROM or
you have pulled really new ROM from a car and no definition yet.
Open the rom with no definition in Ecuflash, it will tell you it does not have a definition, do you want to create one. You press yes, and then click on from scratch. Then you choose SH72531 under memory module, and Subarubrz flashing method. The unique identifier is at 8000 and 8 bytes long. Fill the rom info in with the year, model etc. - not critical that this is accurate if you're just using it to flash. Click Finish, and when you're back in Ecuflash, click on file, and 'Save Models'.
This should allow you to flash ROM but not edit as no tables defined.
AussieBRZ is offline   Reply With Quote
Old 09-22-2022, 02:59 AM   #4
AussieBRZ
AussieBRZ's Avatar
Drives: WRB BRZ
Full info see here
https://www.ft86club.com/forums/showthread.php?t=62332
or laternativly use the A01I its compatable as the guy above stated
Old 09-22-2022, 03:25 PM   #5
Evolution99
Drives: '15 GT86
Thanks guys for your inputs.
So, do you mean I can flash an old rom like ZA1JA01I on ZA1JA02K ECU? without any problems? since they are compatable.
Plus, I have tried creating one from scratch, but it work as you said. it won't read tables.
Old 09-22-2022, 05:52 PM   #6
AussieBRZ
AussieBRZ's Avatar
Drives: WRB BRZ
correct whwn you male a flash definition its flash only no editting
i thonk there is full definition for A01K you could try that or
best would be jist switch to the A01I rom and definition its compatable with your 2015 auto trans car
A01I is well definied rom and will work fine in your car as a substitute rom
Old 09-22-2022, 06:04 PM   #7
Evolution99
Drives: '15 GT86
I saw A01I rom and EcuFlash can open it normally. I'll try to flash it and see what is going to happen, but in case something gone south, I can flash original file. Is that correct?
Thank you! I really appreciate your help guys!
Old 09-23-2022, 12:02 AM   #8
AussieBRZ
AussieBRZ's Avatar
Drives: WRB BRZ
yes you can always reflash the olf A02K if needed
brz, ecu def, ecuflash
Look for the ZA1JA03N complete RomRaider Editor Definition definition file. nerve86 Software Tuning 13 06-03-2022 07:42 AM
ecuflash definition file help Plumpkibbles Software Tuning 1 10-13-2018 05:19 AM
Definition of rice? Hot Lava Off-Topic Lounge [WARNING: NO POLITICS] 42 05-30-2014 03:41 AM
AS1 Definition? nixeighty6 Scion FR-S / Toyota 86 GT86 General Forum 93 01-12-2012 01:56 AM
