Old 09-04-2022, 05:29 PM   #1
smeowkey
Drives: 2018
Rev Limiter Operating Differently (after a money shift)
Welp, last Sunday I done it. I kinda sorta money shifted from 5th to 2nd. I was going between 90-100km/h when I grabbed 2nd. I almost caught it in time and dumped my foot onto the clutch and saved it... I think? Thankfully my BRZ (2018) kept going and I got home 90min later without any issues. No leaks. No CELs. Power band feels normal. Engine sounds normal. Status quo.
However today I went to an autocross event and I noticed immediately that my engine revs are no longer bouncing off the limiter. The engine revs up and will smoothly hold itself steady at the red line. No pinging, no bouncing, just sits there, foot buried on the gas pedal, engine holding perfectly at the limit.
So now I'm slightly concerned that perhaps I did damage something...
Thoughts?
2018 BRZ, base model, zero power mods. ~55'000km.
smeowkey is offline   Reply With Quote
Old 09-04-2022, 06:49 PM   #2
Ohio Enthusiast
Drives: 2018 BRZ
That's barely a money shift - 2nd is good to 58 MPH (93 KMH) at 7400 RPM.
Maybe you unlocked a cheat code for a smooth rev limiter?
Ohio Enthusiast is offline   Reply With Quote
Old 09-05-2022, 03:01 AM   #3
soundman98
ProCrastinationConsultant
soundman98's Avatar
my cars done that from time to time. some theories on having grip and slowly building rpm's gives the ecu a chance to catch the revs before they get out of control.
but if you go and bang out some donuts, or start sliding around in the rain, it starts bouncing...
i think you're being too gentle after your 'oops'
fortunately, it was the cheapest money shift ever! i did the same 5th-2nd shift at about 50. i was reaching for 4th and revved for 4th, so it was still a shock when the shift light banged on and the car lurched...
Old 09-05-2022, 10:58 AM   #4
Second can indeed do that. When shifted through the band. It isn’t just the revs it is the impact of it happening so quickly.
Old 09-05-2022, 03:00 PM   #5
humfrz
Welp, last Sunday I done it. ..........
Thoughts?
Welcome to the forum, there, smeowkey -
Maybe you just got lucky.
I suggest you disconnect the negative terminal of the battery, have a half a beer, reconnect the battery terminal and see if it resets itself.
Of course, this method is coming from an old man that, when I first got a computer and it acted up, I would just unplug it, have a class of whisky, take a nap and then plug it back in.
Old 09-05-2022, 09:34 PM   #6
soundman98
soundman98's Avatar
a whole class of whisky?!?
yeah, i can see how that's a problem!
Old 10-04-2022, 06:05 PM   #7
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
don't worry about it, all you did is probably tighten some slack on the chains.
I almost money shifted it once as I saw my rpm jump to 8.2-8.3k & caught it with my feet.
WTB: Money Shift TOB BlaqkHavok Want-To-Buy Requests 0 08-07-2021 07:32 PM
Money Shift TOB NV89 Transmission and Driveline 3 11-14-2019 10:43 AM
Money shift.. Where to go from here Benadryl Issues | Warranty | Recalls / TSB 16 06-05-2017 09:42 PM
Money gear shift? accel Scion FR-S / Toyota 86 GT86 General Forum 56 04-17-2017 05:53 AM
Rev Limiter When Changing the Shift Light/Beep Setting....? ShaneLindley Engine, Exhaust, Transmission 3 10-02-2015 12:18 AM
