Drives: 2015 Blue Pearl
Rev Limiter When Changing the Shift Light/Beep Setting....?
OK, this was a weird one....
Yesterday I changed the Shift light/beep setting from 7k down to 4k just to remind myself to save some gas. So I start it up this morning to go to work. Check engine light comes on. I let it idle down and then back out of the driveway and ease down the street. Get out on the main road and tach it up a bit. Tach needle started bouncing at 4k. Did that for my whole 20 mile commute. Felt and acted exactly like a rev limiter. Took it in to dealer at lunch and it ran fine getting there. Subaru service couldn't reproduce problem but told me the code was "U0155-Lost communication with instrument panel cluster". Going to try to reproduce it at a different rev setting. Anybody else run into this? '15 BRZ Limited with 2k miles. |
#2 | |
![]() humfrz |
#3 | |
The reason your rpm was limited to about 4k was because of the check engine light and cel code U0155, this puts ecu into limp home or low power mode where rpm is limited to about 4k and safe timing and fueling tables in ecu are used. Once the code cleared all will go back to normal. do you have any obd port device plugged into your obd port like scanner guages ect, these can sometimes interrupt the can buss signals and cause ecu to loose communication with dash cluster, causing that code and limp home mode especially if you plug or unplug them while engine is running if nothing in obd port its likey your dash cluster may be faulty of its connection to can buss |
Thanks Steve99. Makes perfect sense. The Techs said they increased the connector pin pressure and couldn't replicate the problem.
Did someone say RPM"s"?? Minute"s"?? |
| Ecliptech Shift-i shift light | dp1 | Tracking / Autocross / HPDE / Drifting | 9 | 04-16-2015 06:46 PM |
| Shift light setting | Elkton86er | Engine, Exhaust, Transmission | 3 | 11-29-2014 09:17 PM |
| Does changing fog light to LED render its use nonfunctional? | tracerit | Cosmetic Modification (Interior/Exterior/Lighting) | 8 | 09-10-2013 04:59 PM |
| what does the rpm shift indicator beep sound like? | pr086 | Scion FR-S / Toyota 86 GT86 General Forum | 10 | 07-26-2012 01:28 AM |
| Setting rev indicator light video | ayau | BRZ Photos, Videos, Wallpapers, Gallery Forum | 3 | 06-09-2012 10:58 PM |
