Drives: gr86 2013
Alarm activate when i try lock the door
I've been on Holiday for 3 week. When i turn home i try to start my gt86 - 2013 and nothing. Battery was dead. Not big deal. after charging car start and drive but i cant lock it. When i try lock door using key it behaviour like bonnet or trunk is open. The same after a few second when it try lock itself. It beeps a few time than alarm starts. What can i do? Maybe faulty sensor or immobiliser was the reason battery get flat?
Thanks |
ProCrastinationConsultant
the factory alarm or aftermarket alarm?
Drives: gr86 2013
Factory alarm
have you checked all the doors, and trunk that the sensors are working correctly?
Drives: gr86 2013
im not sure how check sensors. Car behaviour as usual. i try to find out how to check it. If you know how ill appreciate if you give me some tips
the dash open door indicator should display only when doors or trunk are open
Drives: gr86 2013
So it indicate all doors are closed.
3weeks, a stock vehicle generally shouldn't end up with a dead battery.
if the batteries slightly old, might just need to reset the car? unplug the battery for a good hour or so, then reconnect. you also checked all the door trunk switches that they're in proper operation?
Drives: gr86 2013
All seems to be fine. I take it to work today, drive all fine but simply don't want to close. Leave it for 8 hour with unplugged battery - the same. Most likely one of door/hood sensor get bad - but witch one? i think maybe trunk one cause hood one is really simple, and after i close door windows go back up so it seems like car know door is closed.
or some immobiliser iself is faulty - draining battery. But where immobiliser lives? i try google it - unsuccessfully :/ |
| How to activate brz limited alarm | Lee358 | DIY (Do-It-Yourself) Guides | 129 | 05-17-2024 08:21 AM |
| Door lock refresh | stranger things | Cosmetic Modification (Interior/Exterior/Lighting) | 5 | 05-29-2017 08:56 PM |
| Don't forget to activate your alarm! | BRZnut | BRZ First-Gen (2012+) — General Topics | 49 | 04-28-2016 01:23 PM |
| Activate your alarm!! | engee | NY / NJ / CT / PA | 10 | 06-09-2015 12:45 PM |
| Lock door with fob while car is running? | jhh3000 | BRZ First-Gen (2012+) — General Topics | 2 | 06-05-2014 12:04 AM |
