Old 07-30-2022, 01:25 AM   #1
nichiolas
Drives: GT86
Red face Help please!! Reverse Lockout Stuck
Hey guys,
I need some help here please.
I was straying to install the Cusco Reverse Lockout in my car. I was able to hammer the roll pin out(with great efforts of course). However, after switched to the Cusco lockout and pushed the pin back in, I noticed that the reverse lockout is very hard to slide up and down(almost stuck there and require much force to push up/down). Also, it won’t return to the original position by itself once I slide up to reverse position.
The spring worked perfectly fine after I pushed the pin out(left the punch key in there) and the reverse lockout is smooth as it should be. The above issue happened only after I reinstall the roll pin.
Any idea of what might go wrong please?
Thanks 🙏
nichiolas is offline   Reply With Quote
Reverse Lockout Suba-dude64 Want-To-Buy Requests 0 10-08-2019 07:41 PM
Where can I find a reverse lockout pin for the stock lockout? tracerit Cosmetic Modification (Interior/Exterior/Lighting) 0 05-15-2019 03:41 AM
OEM Reverse Lockout Pin Stuck mcrane Cosmetic Modification (Interior/Exterior/Lighting) 16 06-01-2017 08:33 PM
WTB: OEM Reverse Lockout Ethereal05 Want-To-Buy Requests 2 07-18-2016 04:01 PM
Reverse lockout? MrMarinakos Cosmetic Modification (Interior/Exterior/Lighting) 0 04-28-2014 08:47 PM
