Old 08-19-2012, 07:37 PM   #1
ArKiTeCkT
ArKiTeCkT's Avatar
Drives: 2010 Gen Coupe, 2013 BRZ 6MT S.Tech
DIY? Or bring it to the dealer?
This is my first brand new car and I was told that I shouldn't be changing my oil myself or an auto repair shop because it could VOID the warranty. Instead I should bring it to the dealer so they have a record.
Scenario 1
I change my engine,transmission, differential oil and later down the road(2 years) I have an issue with the differential(knock on wood). I bring it to the dealer would they reject my claim because it has never been serviced at a dealer?
ArKiTeCkT is offline   Reply With Quote
Old 08-19-2012, 07:39 PM   #2
Those Meddling Kids
Drives: 2013 SWP BRZ limited
Keep receipts and detailed records. There are several good smartphone apps for this.
Those Meddling Kids is offline   Reply With Quote
Old 08-19-2012, 07:42 PM   #3
goincarcrazy
Future FR-S Owner
goincarcrazy's Avatar
Drives: '05 Scion tC
You don't have to have the dealer touch it ever again after you drive it off the lot. It's on you if you wanna keep the car running well and such by doing the maintenance yourself. The only thing that would void the warranty is if there are parts that aren't stock, and even many of those are acceptable.
goincarcrazy is offline   Reply With Quote
Old 08-19-2012, 07:44 PM   #4
ArKiTeCkT
ArKiTeCkT's Avatar
^Plan to keep it stock until the warranty expires. But maintenance is what I would like to perform myself.
Old 08-19-2012, 07:46 PM   #5
Fazzster
Fazzster's Avatar
Drives: 2022 Hyundai Kona N, 2022 Miata
The Subie engine has a top mount oil filter like my VW's 2.0T so there is no reason to get under your car or bring it to a dealer for oil changes. Just buy a good oil extractor and make your life a lot easier. Keep the receipts for your filter/oil and you are all set. DIY maintenance should not void your warranty.
Fazzster is offline   Reply With Quote
Old 08-19-2012, 07:47 PM   #6
QFry
QFry's Avatar
Drives: '13 Argento FR-S
they would have to prove that you performing your own maintenance is the reason it failed, or that your lack of doing adequate maintenance caused it. So if your diff failed because you put motor oil in it instead of gear oil...voided...if you under/over filled with correct fluids or didnt properly install drain plug...could be voided. I have always done and will always do my own PMS on my vehicles, so take this as my opinion.
2013 Argento FR-S -> Lots of random PlastiDip, UNIChip Custom Tune, aFe Takeda Intake, Nameless Performance front pipe and axle back exhaust, Motegi MR125 7.5x17, Rally Armour mud flaps, Gloss black vinyl roof, ACT street clutch and flywheel,Whiteline bushings; Kartboy Shortshifter and shift bushing
QFry is offline   Reply With Quote
Old 08-19-2012, 09:16 PM   #7
roddy
roddy's Avatar
Drives: '13 Ultramarine
I agree with the above comments. Keep all your receipts and record date/milaege in your owner's manual. For a "good faith" vote, get your oil filters/drain plug washers at your dealership.
Old 08-19-2012, 09:30 PM   #8
Lonewolf
Lonewolf's Avatar
Drives: Moped
As others have said, as long as you have receipts of parts, fluids and you keep a detailed service log with service description, date, and mileage, you'll be fine.
Old 08-19-2012, 09:48 PM   #9
MY13FRS
***** Super Senior Member
MY13FRS's Avatar
Drives: 13 FRS
I agreed with keeping all the receipts for parts, etc.
However, if you are paranoid as myself, just book a time later in the day, say 1 hr before closing and just drop off the car and wait there for the service to get done. Wait at the stealership and try to sneak a peak at your car once in a while to make sure someone didnt go for a joy ride.
This is a 1st year car so I expect more visits to the stealership for TSBs and recalls, so I am not taking a chance with them disputing on warranty work due to missing maintenance records, etc.
MY13FRS is offline   Reply With Quote
Would you buy a car from a dealer that stuck a dealer (ad) plaque or sticker on cars? HitTheGas Off-Topic Lounge [WARNING: NO POLITICS] 49 04-29-2013 03:37 PM
Garage Life: We bring your dreams to life! Garage Life Southern California 0 08-17-2012 07:33 PM
Don't bring a knife to a gun fight... RRnold Off-Topic Lounge [WARNING: NO POLITICS] 9 03-15-2011 08:46 PM
