Old 07-24-2022, 01:48 PM   #1
IsaiahW
IsaiahW's Avatar
Drives: 2013 Subaru brz limited
Hydraulic clutch regrets
I now understand why companies just don’t deal with hydraulic bearings. After installing everything and bleeding the clutch i notice i kept getting air no matter what. Coming to find out i have a leak from the tilton bearing on the bleeder line which requires dropping the trans AGAIN just to tighten a line. Anyone know a way i can test this line out before installing trans back to ensure it’s properly sealed?
IsaiahW is offline   Reply With Quote
Old 07-24-2022, 06:04 PM   #2
Grady
Grady's Avatar
It’s an AN fitting, 99.9% of the time there is no issue if torqed correct. If you are having issues I would add Seco seal to it.
You say you are getting air intrusion without fluid leaking? Sound like there may be another issue?
DIY - Swap clutch slave cylinder and hydraulic line for improved feel and control Ultramaroon DIY (Do-It-Yourself) Guides 452 02-18-2023 10:58 PM
Regrets on Automatic? Ymerej Scion FR-S / Toyota 86 GT86 General Forum 312 03-24-2020 10:42 PM
Any Modification regrets? No5ki Scion FR-S / Toyota 86 GT86 General Forum 52 03-29-2016 09:03 PM
Any regrets? White0utFrs Scion FR-S / Toyota 86 GT86 General Forum 57 04-14-2014 06:15 PM
Regrets pinoyplaya Scion FR-S / Toyota 86 GT86 General Forum 133 04-11-2013 10:14 PM
