Old 07-14-2022, 12:23 PM   #1
loungin
Drives: 22 gr86
gen2 parts for oil change?
Anybody know the part numbers for the oil filter, crush washer, drain plug for GR86? Also, anybody have torque numbers for the filter assembly and drain plug?
loungin is offline   Reply With Quote
Old 07-15-2022, 07:33 AM   #2
spcmafia
spcmafia's Avatar
Drives: 2018 Subaru BRZ
Filter and gaskets are the same as 13+ models. Both BRZ/86. You can find oil change kits at FTSpeed and 86Speed.
Im not completely sure on torque specs though I can only assume is about the same as first gens.
Get a fumoto valve, if you can, if compatible.
spcmafia is online now   Reply With Quote
Old 07-15-2022, 07:58 AM   #3
dragoontwo
dragoontwo's Avatar
Drives: 22 BRZ limited
The '22 filters are different. It has gone to the WRX filter now. I think it is the 170 vs the 130.
dragoontwo is offline   Reply With Quote
The Following User Says Thank You to dragoontwo For This Useful Post:
spcmafia (07-15-2022)
Old 07-15-2022, 09:07 AM   #4
spcmafia
spcmafia's Avatar
Good to know, FTSpeed has their oil package with the 13-20 filter included.
The Following User Says Thank You to spcmafia For This Useful Post:
dragoontwo (07-15-2022)
Old 07-15-2022, 09:13 AM   #5
dragoontwo
dragoontwo's Avatar
In the grand scheme of things either filter is likely fine, until you have an engine warranty issue and they try to be ****s because you used the wrong number filter.
Old 07-15-2022, 09:30 AM   #6
spcmafia
spcmafia's Avatar
This is true. I went to Subaru Parts of America and did a little more digging.
Correction to my previous response.
Oil Filter Part Number: 15208AA170
Crush Washer:803916010 (There's different ones listed)
Torque: 28.9 Ft/Lbs (Or whenever is nice and snug if you don't have a torque wrench)
Don't need to replace the plug every time, just try not to damage it. (17007AA010)
Fumoto Valves: F-108, F-108N, F-108S, F-108SX
Question regarding what parts from Gen1 will fit Gen2 370zBRZ GR86 General Topics (2nd Gen 2022+ Toyota 86) 4 03-21-2022 12:52 PM
2019 Engine into 2013 Chassis - Parts Change List Car Bloke Engine, Exhaust, Transmission 8 10-26-2020 11:11 AM
Timing Cover Leak - What other parts should I change while I'm in there? FR & S Engine, Exhaust, Transmission 7 12-09-2019 02:39 AM
First oil change parts question stlgrym3 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 15 10-26-2018 02:59 PM
e85 tune. change rubber parts? asphalt_fr-s Software Tuning 5 03-25-2014 11:28 AM
