Old 07-13-2022, 08:59 AM   #1
Compelica
Compelica's Avatar
Drives: 86 GT
Bleeding the ABS module
I'm trying to see how this procedure fits in after changing brake fluids or working on something brake related - I don't see technicians doing this often, or even at all.
Most guides specify that the ABS bleeding procedure be done (via dealer tool or shorting certain pins on the OBD2 connector) prior to bleeding the lines. To note, even the service manual does not specify ABS module bleeding as a step.
I performed this procedure (although without bleeding the lines after) and the pedal immediately felt much stiffer. It would only need a light tap on the brake pedal to get the same amount of stop as compared previously.
I then measured the brake pressure at full press - previously the system would only manage 11MPa, after the procedure was done it was now at 13MPa. Of course no one would be applying that much pressure at that level, but it shows that more pressure can now be transmitted to the brakes which is a good thing.
Has anyone performed this procedure as well when bleeding brakes?
DIY stuff at Compelica Works
Compelica is offline   Reply With Quote
Old 06-08-2023, 11:52 PM   #2
J4RF
S🅱️inalla
J4RF's Avatar
Drives: 2013 Subaru BRZ [WRB]
How did you go about bleeding the ABS system?
J4RF is offline   Reply With Quote
bleeding Legend@wheels Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 13 12-20-2018 12:20 AM
brake bleeding, air in abs? Grip Ronin Suspension | Chassis | Brakes -- Sponsored by 949 Racing 13 11-22-2018 07:34 PM
Bleeding Air through TPMS GarStar Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 05-05-2015 02:14 PM
WTT - 2014 Scion Bespoke Nav Module for Toyota AHA Nav Module Danklvr Audio/Visual, Electronics, Infotainment, NAV 1 09-04-2014 05:57 PM
My Car is bleeding! Ec1990 Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 5 04-01-2014 10:31 AM
