Old 07-09-2022, 03:36 AM   #1
Nigruto
Nigruto's Avatar
Drives: Toyota 86 2013 Manual
Exhaust help please!!!
Hi all,
Turbocharged and running strong for almost two years. Recently in my state there has been mass issuing of noise testing by the EPA with the police. So I would like to take a precaution and change my exhaust to as close to stock as possible without needing a retune hopefully.
My current exhaust system is stock front pipe and invidia N1 catback. I still have my stock catback and wondering if this will be ok for my car as I’m not sure if it’s that restrictive. Not sure if even a stock catback with muffler delete would be fine for the turbo.
Any advice appreciated thank you.
Nigruto is offline   Reply With Quote
Old 07-09-2022, 08:55 AM   #2
BirdTRD
Simply Forgotus
BirdTRD's Avatar
Drives: 2014 Supercharged SSM BRZ Limited
I'm supercharged, running a full custom 2.5 exhaust...UEL header, high flow cat in front pipe, 1 resonator, cutout valve, another resonator, then the stock muffler. It's quiet, unless I crack open the valve.
As for performance/restriction, there was only a 5hp difference on the dyno when it was run with the cutout valve wide open (no muffler) and with it closed.
BirdTRD is offline   Reply With Quote
Old 07-13-2022, 05:10 PM   #3
Muskoka800
Drives: 2016 Scion FRS Release Series 2#439
Put the OEM Cat-back on. You’ll notice no power loss and your neighbours will start to like you again.
Edelbrock S/C with CSG 94 & 91 maps
TRD Short Shifter, CTS-V/EvoX Brembos
Ohlin’s R&T Dampers, Hotchkis F/R Bars, Blox LCA & Toe Arms
235F/245R Conti ECS on TRD/Enkei wheels (street),
245/40 sq. ECF on 17x8 720Form GTF2 wheels (track)
Muskoka800 is offline   Reply With Quote
Old 07-13-2022, 10:29 PM   #4
whataboutbob
AutoX-10/10ths every run
If you're not wanting to go back to the stock catback, this is a nice choice.
https://shop.namelessperformance.com...et-track-pipe/
Build thread:Here
Old 07-15-2022, 12:10 AM   #5
jflogerzi
jflogerzi's Avatar
honestly I really enjoyed my fujitsubo-authorize-s-axle-back-exhaust if you still have stock mid pipe. Fully catless it was still pretty tame. Here is a sound clip on the track with Mic at the trunk area.
2013 Series 10 FRS #553
CSG Touring86 Competition Catback Exhaust NEW - Track-ready, mature exhaust note ajcarson11 Engine, Exhaust, Bolt-Ons 3 04-29-2018 07:21 PM
FS [SOCAL]: TRD Dual Exhaust & Stock Wheels w Tires: Exhaust SOLD. gt860 Engine, Exhaust, Bolt-Ons 6 04-28-2018 06:24 PM
Will midpipe from Spec-D Tuning exhaust work on a Megan Racing OE-RS exhaust? neonknight77 Engine, Exhaust, Transmission 13 01-09-2018 05:11 PM
Another project teaser. Exhaust hole covers for single exit exhaust! Wonderbar Cosmetic Modification (Interior/Exterior/Lighting) 57 05-30-2014 01:46 AM
Revive Your Exhaust Tone with Our Debut FT86Club Exhaust Clearance Sale! FRSport.com Engine, Exhaust, Bolt-Ons 0 09-06-2013 02:08 PM
