Old 07-09-2022, 03:01 AM   #1
Kulebrero1
Drives: Gr86
Suspension setup
I ordered a pair of Tarmac 2 coilovers, camber plates, Eibach sway bars, and Voodoo rear lower control arms. Aiming for a track setup…thinking 1 to 1.5in lower will work. Will I need aftermarket end links, and/or any other parts to adjust height and camber?
Kulebrero1 is offline   Reply With Quote
Old 07-09-2022, 11:59 AM   #2
Racecomp Engineering
With the adjustable swaybars, I would recommend adjustable endlinks as well.
Nothing else needed. Toe arms with eccentric lockout are IMO nice to have to make alignment easier and prevent slippage but not required.
- Andrew
Old 07-11-2022, 05:25 AM   #3
EndlessAzure
Wheels for Brains
EndlessAzure's Avatar
Drive the car first, tune the balance and run out of adjustment on the coilovers before adding sway bars.
EndlessAzure is offline   Reply With Quote
Old 07-11-2022, 08:18 AM   #4
ZDan
ZDan's Avatar
Drives: '23 BRZ
FWIW I'm running the factory end links with Eibach sways front and rear, ride height about 1.25" lower than stock. With factory links you kind of have to run the stiffer of two rear settings but that was what I want/need anyway...
I believe some aftermarket links may limit how much negative camber you can run up front before they impact the inside of the wheelwell so you might try factory links first, at least up front.
Kulebrero1 (07-19-2022)
Air Suspension Setup nwgabrz Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 03-08-2022 03:31 PM
Suspension setup hpde_addict Northern California 0 11-08-2017 05:52 PM
Suspension Setup? ImAdopted Suspension | Chassis | Brakes -- Sponsored by 949 Racing 18 08-18-2017 03:56 AM
Different Suspension setup on BRZ? Trmx2 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 11-13-2013 08:36 PM
setup of suspension jdzumwalt Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 11-21-2012 03:03 PM
