Old 07-06-2022, 02:42 PM   #1
allowe
allowe's Avatar
Which grease do I use when replacing the clutch
Hey guys, my TOB likes to howl every time I turn my car on so I went ahead and ordered a clutch kit, flywheel, the new tob, clutch fork and pivot. I’m going to tackle this job next week when I’m off.
The kit came with a little grease packet. I was wondering if it’s enough to use for the whole job, or should I get bottle of grease And if so, which type of grease should I get?.
Currently my clutch fork squeaks when I press the clutch. Id like for the new setup not to have said squeak.
allowe is offline   Reply With Quote
Old 07-06-2022, 02:46 PM   #2
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
The squeak might be at the firewall.
With the said, it doesn't take much grease at all, what they provide should be adequate
JDL EL Recirc manifold, Boostlab BL58x Turbo w/ T51R, 17x9 ARC-8, IAG block
The Following User Says Thank You to DarkPira7e For This Useful Post:
allowe (07-06-2022)
Old 07-06-2022, 03:29 PM   #3
demasrv
demasrv's Avatar
Drives: 2013 Rally Blue BRZ
Any high temp brake grease or a high temp lithium grease should do the trick.
Sent from my Pixel 4 using Tapatalk
demasrv is offline   Reply With Quote
Old 07-06-2022, 07:20 PM   #4
RZNT4R
Professional Mechanic
Drives: 2017 86 6MT Oceanic
The little packet of grease is SPLINE GREASE to be used applied in a thin even film on the input shaft splines. empty the packet as evenly as possible on the input shaft and slide the clutch disc on it a few times and in a few orientations to evenly distribute, wipe off excess.
For the clutch fork, clean off the contact point where it pushes on the throwout bearing, where it pivots on the fulcrum and where the slave cylinder pushes on it. A dab of extreme pressure moly grease will do. It's basically the same thing as in the little packet, but you need that little packet for the splines, and the little packet is a thicker viscosity so it doesn't fly out into the clutch disc.
The Following User Says Thank You to RZNT4R For This Useful Post:
soundman98 (07-06-2022)
Clutch fork grease BlOody_BoOger Engine, Exhaust, Transmission 5 05-28-2021 07:02 PM
Clutch/Trans Grease Recommendations/Application Olson1288 Engine, Exhaust, Transmission 5 11-27-2020 09:47 AM
I found coolant in my exhaust while replacing my clutch legojerry Issues | Warranty | Recalls / TSB 17 08-14-2020 12:46 AM
Difficulty of replacing clutch (VS FWD car) RWD fun Engine, Exhaust, Transmission 8 06-15-2020 04:30 PM
Need opinions on replacing clutch please Polmtree Scion FR-S / Toyota 86 GT86 General Forum 3 04-05-2019 08:15 AM
