Old 07-02-2022, 09:49 PM   #1
Celigts
Celigts's Avatar
Drives: 2014 Toyota FRS
Timing chain cover oil leak - REPORT
This is an extremely common issue and needs to be addressed. Poor quality sealant was used and we weee never issued a fix from the manufacturer. Just told to fix it by paying over $2000 for an issue that the manufacturer caused.
Report it to
https://www-odi.nhtsa.dot.gov/VehicleComplaint/
Oil leaking from the engine on the driver side is a safety hazard.
Hopefully this gets addressed.
Celigts is offline   Reply With Quote
Old 07-02-2022, 10:23 PM   #2
Ultramaroon
not playing cards
Ultramaroon's Avatar
It was addressed in the owner's manual and the warranty. Have you read either?
Old 07-02-2022, 11:22 PM   #3
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
My timing cover has never leaked when I re-installed it properly. I think it's workmanship, not manufacturer
JDL EL Recirc manifold, Boostlab BL58x Turbo w/ T51R, 17x9 ARC-8, IAG block
Old 07-03-2022, 12:09 AM   #4
Ultramaroon
not playing cards
While it happens, it is not common. It is definitely NOT a safety issue.
edit: It also tends to happen with an engine that's been fucked with six ways to Sunday. OP needs to sack up, and own up.
Old 07-03-2022, 09:24 AM   #5
RZNT4R
Professional Mechanic
Drives: 2017 86 6MT Oceanic
Man, imagine if this guy had a EJ :lol
Old 07-03-2022, 11:15 AM   #6
soundman98
ProCrastinationConsultant
soundman98's Avatar
i thought self-oiling/anti-rusting was a feature?
Dipstick leak vs Timing Chain Cover jpeaslee Issues | Warranty | Recalls / TSB 6 03-03-2017 12:33 AM
Oil leak - timing chain cover CB762 Issues | Warranty | Recalls / TSB 3 08-24-2016 04:45 PM
Can Toyota's 103 FIPG silicone be used in timing chain cover? Astroboy Engine, Exhaust, Transmission 16 08-24-2016 12:16 PM
Timing Chain Cover Leak alexand3r Engine, Exhaust, Transmission 17 09-29-2015 11:05 AM
Timing Chain Cover Replacement - Need Advice Gen Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 4 04-02-2014 12:15 PM
