Old 06-29-2022, 10:21 PM   #1
scion fr-s
scion fr-s's Avatar
Drives: 2017 PP BRZ
Splitter Connector to run FF and O2 sensor
Hello,
Does anyone know if someone makes a splitter connector like the one in the picture? I am trying to run a flex fuel sensor and o2 sensor at the same time. Any help would be greatly appreciated.
scion fr-s is offline   Reply With Quote
Old 06-29-2022, 11:07 PM   #2
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I don't think it will work. I believe using the FF kit that connects to the secondary o2 and a corresponding tune hijacks the A/F compensation table associated with that sensor for the ethanol content compensation. Someone more knowledgeable about it can probably correct me, or elaborate more.
Here's the table it uses.
https://www.ft86club.com/forums/show...78&postcount=4
The Following 2 Users Say Thank You to NoHaveMSG For This Useful Post:
scion fr-s (07-05-2022), Ultramaroon (06-30-2022)
Old 06-30-2022, 01:51 AM   #3
Ultramaroon
not playing cards
Ultramaroon's Avatar
^^ This ^^ Need an input channel when there are no extras. Repurpose the least important one.
Old 07-09-2022, 04:27 PM   #4
86TOYO2k17
Drives: 2017 toyota 86
Just use the cpc input for FF.
2013 Oil Temperature Sensor Connector Spairo Engine, Exhaust, Transmission 2 12-27-2021 11:36 PM
What connector does the evap sensor use? aznchris Electronics | Audio | NAV | Infotainment 0 03-09-2020 03:21 AM
Whats the name of this connector (3rd brake light connector) Chimera Cosmetic Modification (Interior/Exterior/Lighting) 4 01-10-2017 07:13 PM
Greddy informeter, boost sensor, boost sensor harness, info touch sensor apaptor Supra2k Audio/Visual, Electronics, Infotainment, NAV 1 02-26-2014 09:11 PM
install cruise control coz for me roll connector / steering sensor fail aagun Issues | Warranty | Recalls / TSB 15 11-14-2013 10:29 AM
