Old 12-27-2021, 05:37 PM   #1
Spairo
Drives: 2013 FR-S 6 spd in Halo
2013 Oil Temperature Sensor Connector
I recently found the wiring for the oil temperature sensor yanked out of the connector. Unfortunately, the way the wiring broke, there is nothing left at the back of the connector to strip and repair. The dealer says that the connector is part of the entire engine harness. I am going to see if a junkyard will cut out a connector with a pigtail attached that I can crimp or solder in.
However, I was wondering if the pins in the connector can be purchased somewhere. Does anyone know what type or style, etc. pins that these may be? I am willing to try and repin the connector if I can get the pins.
Sent from my SM-G950U using Tapatalk
Spairo is offline   Reply With Quote
Old 12-27-2021, 10:37 PM   #2
whataboutbob
AutoX-10/10ths every run
Check out https://iwireusa.com/
Build thread:Here
The Following User Says Thank You to whataboutbob For This Useful Post:
Ultramaroon (12-28-2021)
Old 12-27-2021, 11:36 PM   #3
Spairo
Originally Posted by whataboutbob View Post
Outstanding! Connector and pins are ordered and on the way. That site went on the bookmark list.
Thanks for the help.
The Following User Says Thank You to Spairo For This Useful Post:
whataboutbob (12-27-2021)
Where is the ambient temperature sensor located? solidONE Software Tuning 10 09-17-2023 03:21 PM
What connector does the evap sensor use? aznchris Electronics | Audio | NAV | Infotainment 0 03-09-2020 03:21 AM
Oil Temperature Sensor Location g0odspeed DIY (Do-It-Yourself) Guides 4 01-30-2018 11:03 AM
Cabin temperature sensor location avg BRZ First-Gen (2012+) — General Topics 2 06-10-2017 01:06 PM
Oil temperature sensor and cable Junkwipe Electronics | Audio | NAV | Infotainment 0 07-18-2014 11:06 AM
